KewlBird
- Joined
- Oct 6, 2007
- 247
Well to start off it's a 1990 Mercruiser 5.0LX 230hp....with alpha 1.
The engine runs well and idles fine.....After I have it at 3/4 to full throttle for a little bit of time (3-5 minutes) the engine starts to rattle...If I move the throttle back to about 1/2 the rattling goes away! This is when engine is warm or cold. A few days ago I was on it and it started rattling, then puffed a couple of times (as if backfiring) then stalled out! It restarted fine....the temperature is normal when it does it and the oil pressure is ok. I'm guessing that it could be a lean mixture, but wouldn't it rattle all the time when you're on it and not after 3-5 minutes? It feels like it has less power when it does this......BTW, I replaced the fuel filter and it didn't change anything...Could it be the fuel pump not supplying enough fuel? Thanks.
