Favorite Recipes-All Time
D
DJ
Guest
I do 90% of the cooking around here. I'll being doing the traditional Christmas dinner but I have two evening Dinners (guests) that I also need to cook for.
I'd like to try some new recipes.
Since we have a few days before Christmas, I can experiment to make sure I get them right.
What are your ALL TIME FAVORITE recipes that you actually make. I'm open to all suggestions.
Let's see em'.
Thanks.
tashasdaddy
Re: Favorite Recipes-All Time
anything in Paula Deens cookbooks.
Bart Sr.
I LOVE LASAGNE!!!!!!Everyone in this house is happy to hear that we will be having some Christmas Eve.
My "Cheap and Easy Stuff"---------
3lbs ground beef , 2 cups diced onion ,1-1/2 lbs mozz chz(shred)
1qrt small curd ctg chz, 2 tbsp parsley ,grated parmesan chz(lots of this)
3 lbs Prego Thick and Chunky(Your Favorite Flavor) 14 Lasagne Noodles
Salt ,Pepper ,Garlic POWDER to season meat while cooking
While cooking the noodles combine beef,onion and salt,pepper,garlic and cook till beef is done and onions are clear.Drain and return to pan.Mix in the prego sauce and set aside.
Mix cottage cheese,2 tbsp parsley and 2 tbsp parmesan cheese.Mix well.
When noodles are done rinse well with cold water and leave in cold water.
Assembly
I use an oversized chafing dish 15inch X 11inch X 2-1/2 inch.
Place 4 noodles overlapped in dish.Cut a noodle to fill the end space.
Liberally sprinkle parm chz.Add 1/4th of the meat mix evenly.
Dollop the ctg chz evenly.I just power shake by hand.
Evenly place 1/3 of the shredded mozz.Repeat with noodles but press down before adding Parm chz then another 1/4 meat mix 1/3 cottage chz and 1/3 mozz chz.
Again cover with noodles,parm chz,cottage chz and mozz chz and add the rest of the meat mixture LAST.
Finally --Liberally sprinkle parm chz on top of meat.
Bake at 300* for 1-1/2hrs.Refrigerate overnight.
IT IS SO MUCH BETTER THE NEXT DAY!!!!!!!
tx1961whaler
I can't believe that I'm sitting here reading the "Manly Men of the Sea Exchanging Recipes" thread. :) I gotta get out more...
Makes me hungry for Chili.
D
DJ
Guest
A guy's gotta eat! It might as well be GOOD!
fishrdan
Me too,,, had one of my ol' girl friends sisters (try to) make it once. She said the noodles didn't need to be cooked, it was,,, how should we say??? CRUNCHY. :rolleyes::D
We do a number of things when company is over but our favorite is a mixed grill. Throw a few steaks, crab legs, lobster tails, potatoes, acorn squash on the grill and let everyone have at it.
Plainsman
Chicken wings> very simple>deep fry until they float> put in a bowl of Frank's hot sauce and shake. Use real butter to cut the hotness if needed. That's it. Use real blue cheese with some celery and carrots.
Bart Sr.
Not cooking lasagne noodles is LUDICROUS!!!!!!
The crunch factor is not nearly as bad as the starchy taste factor.
The main reason I don't eat out is the fact that I can make food BETTER and CHEAPER myself.
I agree DJ ---It has to be GOOD!!!!!
tashasdaddy
"The main reason I don't eat out is the fact that I can make food BETTER and CHEAPER myself." i totally agree. and i get the protion size is want. restaurants today charge way too much, and serve too much food per portion.
remember the adage " portion size equal to a deck of cards is more than adequate."
mthieme
Oyster Stew Supreme is on the menu this weekend, what with oysters being in season and all here in the Land of Pleasant Living.
4 slices of bacon, cooked and crumbled
1/2 cup butter
1 medium onion diced
2 stalks celery diced
2 garlic cloves crushed
2 TBSP flour
salt
black pepper
pinch cayenne
1/2 Tspn dried thyme
8 oz. clam juice
1/4 cup dry sherry
1 1/2 cups heavy cream
12 oz evaporated milk
peck of fresh shucked Chincotegue oysters with their juice
3 dashes of worchestershire sauce
1/2 cup parsley
Cook bacon, crumble and drain.
On low heat -
Add butter and melt
add onions, celery and garlic, saute until translucent
add salt and pepper, cayenne, thyme, and flour - whisk until smooth
Slowly whisk in clam juice
Whisk in cream slowly, then evaporated milk until smooth
on slightly higher heat, stir until just before boiling, then lower heat
Stir in oysters with juice
add several dashes of worchester sauce and chopped parsley
continue to heat and stir occassionally until edges of oysters curl.
I'm still tweaking this recipe. I will use Old Bay (or J.O.) instead of pepper and cayenne. Old Bay has cayenne in it anyway.
I generally don't add salt to anything, good oysters are already salty, butter is salted too.
I will only use about 1/2 tspn of sherry as it overpowers easily.
I will also use cream in lieu of evaporated milk. Generally I substitute 1/2+1/2 for milk with any recipe to avoid any chance of curdling. You can substitute 1/2+1/2 for the heavy cream too.
LadyFish
I make these two recipes every Christmas Eve.
LadyFish's PRIME RIB
MAKE SURE YOUR ROAST IS AT ROOM TEMPERATURE BEFORE YOU PLACE IT IN THE OVEN, OTHERWISE YOU WILL HAVE AN UNCOOKED ROAST AT THE END OF THE COOKING CYCLE. At least 2 hours.
With the roast bone side down. Smear Dijon mustard, thyme, garlic, salt and pepper on top of the meat or with any desired spices.
Set the oven temperature at 500? F. Multiply the roast poundage on the package times 5 minutes?.. be as accurate as possible! Example: your roast weighs 5.53 oz. Multiply 5.53 times 5 = 27.65. You would set your timer for (27.65) or 28 minutes. At the end of the 28 minutes, turn the oven temperature off. Leave the roast in the oven for at least 2 hours.
NOTE: If you want it less rare multiply the poundage by 6 minutes per pound.
DURING THIS TIME, DO NOT OPEN THE DOOR, as the meat is still cooking. This method will produce a perfect prime rib, guaranteed, every time, if you follow the instructions carefully.
YORKSHIRE PUDDING
3 eggs
1 1/4 cups milk
1 1/4 cups all-purpose flour
3 tablespoons chopped fresh mixed herbs such as chives, thyme, and parsley
Kosher salt and freshly ground black pepper
1/4 cup reserved beef drippings or melted butter
Preheat the oven to 450 degrees F.
Place an 8 by 12-inch enameled cast iron baking dish or muffin tin in the preheated oven for 10 minutes. Meanwhile, in a mixing bowl, beat the eggs until foamy and light. Whisk in the milk until combined. Add the flour, herbs, a big pinch of salt, and some pepper, beat just until the batter is smooth. Pour the beef drippings into the bottom of the hot pan. Immediately pour in the batter and bake for 10 minutes. Reduce the oven temperature to 350 degrees F and continue baking for 15 to 20 minutes until the pudding is puffy and brown. Serve immediately, it deflates rapidly.
LadyFish's SCALLOPS AND SHRIMP IN CREAM SAUCE
1 lb. scallops
1 lb. shrimp
2 1/2 oz. butter
3 tbsp. Flour
1 tbsp tomato paste
1/2 pt. (1 c.) milk, heavy or whipping cream
1/3 pt. wine
Bake scallops for 20 minutes at 350 degrees with butter and dash of wine. Steam shrimp 3 to 5 minutes. Melt 2 ounces butter. Add flour to make paste. Slowly add milk. Add wine, tomato paste and touch of juice from scallops. Stir until it thickens. Cover on low heat. Add cream sauce to shrimp and scallops. Cook 2 minutes at 350 degrees. Serve in pastry cups. I use cresant rolls in a can, cut them to size and back them in muffin tins. It serves as the perfect vessel for this side dish. Serves 6.
Pony
I do 100% of the cooking here. The girlfriend can't even work the coffee maker. I enjoy it though. My dad went to chef school for 3 years so when I was growing up he spent a lot of time showing me stuff. I know I have posted food pictures here before, but my favorite foods to make are......
  1. Beer Braised Baby Back Ribs
  2. Chicken Soup with bread Sinkers
  3. Goulash......chicken or beef
  4. I make a pretty mean Chili (Venison, beef,and pork)
  5. A host of homemade sausages (polish, italian, and a few slovak rice/liver sausages)
Bart Sr.
If you don't like a lot of preparation this one is good for you.I got this from a Lions Club cookbook.
Yummy Chicken
4 boneless/skinless chicken breasts
6 slices SWISS Cheese
2 cans cream of ???? soup(chicken-celery-mushroom-????) your choice. I use celery and mushroom.
1 box stove top stuffing
In a medium chafing dish pour one can of soup to cover the bottom.
Place the chicken on the soup.
Place the SWISS cheese on the chicken to cover well.
Pour the other soup over the SWISS cheese and spread to cover evenly.
Top with the stuffing(dry.uncooked).
Do not add water to the soups.
Bake at 350* for 1 1/2 hours.
I could eat this once a week with no problems!!!!!!
Bob_VT
Carefull people! We keep this up and we will have to start a new iboats section Cooking and Etiquette :D
LadyFish
Naaaa, the "Etiquette" part will never fly 'round here. LOL ;)
QC
I'm thinking if we keep this up we'll have to start a section called Excercise and Dieting . . .
Don S
They call that spring time :rolleyes: :D
Ayuh,.... That pretty much explains My life.......;)
