fiberglass relic restoration
Scott Chinsota
rain..
rain..
i got brave and did what i could between waves of showers. managed to get the last two deck panels in along with the pvc pipe and battery cables. managed to pb around most of the two panels, then the rain stopped me. couldn't tab them in. had to tarp the boat and wait til tues. 100% chance of rain today but 10% chance or less for the 9 days following. after the rain stopped my activity outside, i move to the garage and finished cleaning the disassembled steering box. new grease and re-assembled. already did the cable so that's ready when the time comes. should feel like power steering compared to the way it was.
Scott Chinsota
progress...
progress...
tabbed in the bow sections except two spots i had to wedge. ran a strip of csm across the seam between panel 2 and panel 3. wifey took the camera to work.
tomorrow: pb and tab where wedges are, wrap csm over edge of step. maybe do the 2nd layer (1708) of tab around perimeter. pics if she leaves me the camera.
stepped in my strip across seam reaching for roller :facepalm:...fixed it...did it again :eek:. i was barefoot. hope my sock comes off when i get home. normally i woulda been irate, all i could do was laugh. :D
zopperman
Re: progress...
Re: progress...
PICS OR IT DIDN'T HAPPEN!!! :D
I got covered in resin. the suit didn't help, I got it in my mouth, it's nasty stuff. I wound up laughing by the end of it too.
proshadetree
Re: progress...
Re: progress...
Been there done that. Mama was not pleased. But I gota agree it was funny when I did it too. Fumes maybe? Great boat there man.
Scott Chinsota
Re: progress...
Re: progress...
almost late for work yesterday, forgot to dunk roller in acetone before i left. got up, ready to go at it, roller is one solid piece :facepalm:...is now soaking. thought about pics, can't find camera. wifey left to pay bills.
Gonna search the house for the camera.
Scott Chinsota
pics finally...
pics finally...
2011_1102mycardfirst0001.jpg2011_1102mycardfirst0002.jpg2011_1102mycardfirst0023.jpg2011_1102mycardfirst0025.jpg2011_1102mycardfirst0024.jpgthese are the largest pieces of the deck and stringers. the rest was paper mache. nicely rotted aye?
Scott Chinsota
Re: pics finally...
Re: pics finally...
2011_1102mycardfirst0010.jpg2011_1102mycardfirst0022.jpg2011_1102mycardfirst0009.jpg2011_1102mycardfirst0020.jpg2011_1102mycardfirst0018.jpgthe drain tube flaring tube with watts A-338 short forged flare nut, boat squared on trailer, rebuilt steering box...shoulda took pics of it disassembled, sorry, the patch over the redrilled drain tube hole in transom, and the patch for the livewell from the outside...not finished yet.had to raise it 1/4 inch.
Scott Chinsota
more pics...
more pics...
2011_1102mycardfirst0003.jpg2011_1102mycardfirst0004.jpg2011_1102mycardfirst0005.jpg2011_1102mycardfirst0006.jpg2011_1102mycardfirst0007.jpgseat stand/battery cover, live well and rotted lid, last pic shows resin cracks from no fiberglass.
Scott Chinsota
Re: more pics...
Re: more pics...
2011_1102mycardfirst0008.jpg2011_0907secondround0497.jpg2011_1102mycardfirst0014.jpg2011_1102mycardfirst0017.jpg2011_1102mycardfirst0021.jpgfirst pic shows pieces the had to be cut out of stringers in second pic. I realized that if the boat took on water, there would be limited crossflow/equalization. now it can flow freely under the bow section. third and fourth pic...template this! fifth pic shot from deck level...tried to show surface of deck with grain of csm telegraphing through the resin and shows where pvc/battery cables comes out of bow and go up under cap.
wanted to show the stringer mistake because i modified the original design and created the crossflow problem. listing to one side could've sunk the boat. i was lucky i saw the problem and corrected it. back to rule # 1...don't add to or take away from the original design! my adding support for the bow section could have had a disasterous result!
Scott Chinsota
Re: more pics...
Re: more pics...
2011_1102mycardfirst0013.jpg2011_1102mycardfirst0027.jpg2011_1102mycardfirst0028.jpg2011_1102mycardfirst0029.jpg2011_1102mycardfirst0011.jpg
pics 2,3, and 4 are especially for oops. his post about shoveling a path back to his igloo reminded me of winters past so...here's a little sunshine.
1st pic is the whole bow section, the dock where the boat should be, going to the gulf, coming back in, and nieghbor across the canal sunbathing...:D
Woodonglass
Re: more pics...
Re: more pics...
Looks Like everything is coming together well. I can't believe you replaced that NICE wood that was in there. Oh well, Maybe you can build some book shelves out of it!:eek:
Scott Chinsota
Re: after thought...
got a little farther and ran out of hardener. went and bought 2 more gallons of resin and an extra hardener. it's cooled off since july and i had to spice up the resin recipe. . biax tabbing is done, transom got a layer of biax and i plan to do the bow section of deck with biax too. i'll tack pics before i continue. spent 2 hours grinding to prepare for more layup...no bugers, no bubbles :D!
Woodonglass
No you didn't....Without dem pics, it NEEEEEEEEEVER happened!!!:D
Scott Chinsota
Re: update...
Re: update...
took a break for a few days. went supply shopping. transom layup revealed a few bubbles that had to be dealt with. i tried to do the csm over the wet biax.running out of hardener meant tearing off some of the csm that i couldn't wet out and trying to salvage the edges without leaving a huge mess to grind off when it set. over the weekend i'll shoot some now pics and then the fun begins...
i managed to scrounge up the money to biax the entire deck :D:D:D. if i get lucky, the deck will get csm'd over wet biax and i'll still have enough resin to install the 'wells and seatstands.
there will be pictures...:cool:
Scott Chinsota
update...
update...
at the last minute i changed my mind about biax on the entire deck. the bow section ate up so much resin...7oz per sq ft to wet out csm+biax. its the ideal way to go but overkill for this size boat. i csm'd the remainder of the deck and ground off the failure on the bow section. direct sunlight made it kick before i could get it 100%. i knew better than to try it without setting up the tarp for shade. laziness left me with a 6" x 10" stripe to rework :facepalm:. before work this morning, i did most of the prep on the wells. hope to install them tomorrow.
Woodonglass
Re: fiberglass relic restoration
This past weekend I build a 50 ft ocean going yacht out of tooth pics and elmers glue, and used bed sheets for sails. Oh, darn, i forgot to take pics, but she sure is a beaut!!!!! Doesn't leak a drop! I'll post some pics just as soon as I find that darn Brownie Insta-Matic!!!!:p:D
Scott Chinsota
Re: update...
Re: update...
i know, i know. wifey gets all bent out of shape over the pics and the internet. that's why the pics come in the middle of the week...when she's at work. everybody cross yer fingers...if she has dogs to groom, I'll have pics to post.
