Flywheel bolts size? 1978 35hp seahorse
flatsdude3
Pulling the flywheel on a 1978 35hp. Have the puller not sure what size the 3 bolts i should use are? someone suggested 1/4x20 should these work not sure? thanks alot
alangf
Re: Flywheel bolts size? 1978 35hp seahorse
There has been some confusion on this site (and apparently in Evinrude owner's Manuals too) about the size bolts. They should be 1/4-20 on this size and vintage engine. There is a possibility they may be 5/16-24. Whichever size bolts you use be careful to avoid running them in too deep into the flywheel. If you run them in too deep they can contact the coils and make quite a mess.
flatsdude3
thanks for your help i will pickup both sizes and see which fit
