GENERAL CURIOUSITY...Would a boat with a soft or rotten floor have any chance sinking
Lukelona
Re: GENERAL CURIOUSITY...Would a boat with a soft or rotten floor have any chance sin
bump
Lukelona
I think my thread has died... lol
Is anyone still following...?
jbcurt00
Cracks can be either cosmetic & not structural or as you suggested 'caused by hull flexing' which then might indicate rotted underlying structure. Hard to say w/out pix.
It is now starting to warm up in most of the US & parts of Canada, so the dry dock starts to get less frequent visits as guys start working on getting their own rigs ready for the fishing/boating season. Many have already started using their boats.
No idea what color wood was used on your boat, so dry reddish wood isn't meaningful beyond dry. Poly resin typically has a red or green tint to it, so that may be the cause of your reddish wood too.
Having little other then this to go on:
Unless you core sampled the transom by drilling some holes in multiple areas on the transom, and got NO indication of damp wood, a positive motor 'bounce' test is not proof of a sound transom.
Your friend that builds boats didn't think you should core drill the transom?
Lukelona
sorry yes, ive already done drill holes througout.transom. they had dry good wood feel to them, also.had a redish tint.
I have new pics but im having trouble posting them from my new phone.
bear with me im trying them.now....
Lukelona
bump
whats the easiest way to seal the wood back up from chipping this spot off?
would 3M 5200 be sufficient?
Woodonglass
Honorary Supreme Mariner
Chipping what spot off?
Lukelona
I'm sorry I didnt really describe, the transom has the light cracks in gel coat/bilge coating
I chipped away from the crack to look at wood and whatnot.
also there was a delaminated spot on the floor piece in the bilge that I peeled some glass off to let it air out to seal it.
could I just skim some 5200 over these areas to seal it, or do I have to glass it all again?
jbcurt00
I'm sorry I didn't really describe, the transom has the light cracks in gel coat/bilge coating
This is one of the reason it's generally most helpful to have pix included w/ questions. That way we can see what you're seeing. Tough enough remote via the internet, but blind makes it extra tough..................
Chipped away at the glass to look at the wood?
Didn't you core drill to inspect the transom? What did you use to seal the holes where you core drilled?
Removed delaminated fiberglass to let it air out? To seal it?
Lukelona
Didn't you core drill to inspect the transom? yes, shavings were good, not rotten
What did you use to seal the holes where you core drilled? 3M 5200
Removed delaminated fiberglass to let it air out? To seal it? Yes, there was a area on bilge floor delaminated from a chip in the glass coating
Also, the cracks in the bilge coating near the engine bolts sounded kind of delaminated when tapping with screwdriver handle, so I chipped a small area of the glass too see how wet/rotten it may have gotten.
it doesnt look rotten at all, or "feel" wet or mushy...
so I let it all dry for weeks and im wondering how I should seal it back up
I dont have pics of the bigger area on the bilge floor. its about 4"x8" diagonal spot
magnumdeke
Man you are making this harder by having multiple threads going!!!
Lukelona
I know sorry, this one was originally about floors/ stringers etc.
the other thread is meant to be about transom's .
Sorry for confusion I have most of the info I need, any and all is appreciated.... thanks
Alwhite00
Wood looks pretty dark, Did you drill into it?
LK
tpenfield
I think the wood looks OK . . . maybe a good time to check the moisture content, as its slightly dark color could indicate wetness.
You can seal it up with pretty much anything, but ideally just get a little patch of fiberglass cloth and use epoxy or poly resin.
