Glastron V196 restoration
Woodonglass
Im definatly leaning toward the rustoleum
Im very curious to ser how it looks sprayed
Will finish 1 hardner work in the rustoleum
Also anyone tried thinning rustoleum with urathane grade reducer?
Urethane thinner won't work!! Do NOT use it. Totally different chemistry. Yes any Acyrlic Enamel Hardener will work with Rustoleum. You WILL be amazed at how it turns how. Very smooth and shiny and a Hard Finish. Let it cure for 2 weeks then buff her out.
Dennischaves
Vietcu...iv gone through about 14 gallons so far
I still have some bulkheads to tab in
So when im all said and done about 16 gallons total
Dennischaves
No Title
Should i do anything to the tops of the flotation boxes so if any water gets on them through the rod holders its not just going to sit on the foam and creep down the sides
I was thinking grind the foam flat snd a layer of csm??
archbuilder
I would seal it with poly and cms. Once you cut the skin off the foam it is more susceptible to absorbing water.
Dennischaves
No Title
Looking at the deck now that its all cured ....dosent look too bad Got 1 air pocket that i have to grind and reapply csm other than that pretty good
Dennischaves
No Title
Today i got the two bulkheads tabbed in
And i put a layer of csm over the foam in the flatation boxes
I have a lot of sanding to do now on the hull and cap
Hopefully i can start painting next week
Whats better for thinning rustoleum
Acetone,mineral spirits or petrenol?
Dennischaves
It says to thin with acetone but iv read about people thinning it with mineral spirits also
kcassells
I was thinking the same thing also. Got scared so I used Woods recipe and got reducer. I just painted my tank coffin with that recipe and it turned out great! Look on my post today.
Shoot a yoyo to Woodonglass
Woodonglass
It depends on the temps when you're painting 75-85 I'd use Acetone 85-90 A 50/50 mix of Mineral Spirits and Acetone 90+ just use Mineral Spirits
Corjen1
Just caught up on your build...GREAT work so far. When I painted mine, I did the hull first, then, much later, the top after it was final installed.
Dennischaves
I spent all day sanding today
I got the hull and cap all ready to paint
Hopefully next weekend if the weather is good
Im going to paint the hull with WOG's
Rustoleum mix ratio of hardner and thinner
And im going to spray it with my hvlp
Approximatly how much paint will i need
Will 5quarts be enough for 2 coats on the hull and cap
I just dont want to run out half way through spraying
Dennischaves
No Title
I got a lot done today
The boat went from this
Dennischaves
No Title
To this ....
I followed wog's formula with rustoleum
It really came out great
The pictures dont do it justice
Its really glossy
Dennischaves
No Title
More pictures
