JASinIL2006
Thread starter- Joined
- Feb 10, 2012
- 5,769
Hi, I have a Humminbird 385ci GPS+Fishfinder on my boat. I use this not only as depth finder but also for the GPS speedo feature, which is really nice when I'm pulling skiers or tubers. I really like this unit, but every time I turn off the engine (i.e., to allow a skier to climb in or out of the boat), the GPS feature stops working -- it freezes and won't display a speed unless I power-cycle it.
The GPS is powered through an always-on circuit, so it doesn't power off when I shut off the boat. (The GPS/fishfinder only turns off if I manually shut it down.)
I figure something about starting the boat is causing a power spike or dip that interferes with the GPS; has anyone else experience this? Is there any sort of filter or similar device that might insulate the unit from whatever is causing the GPS to flake out? I do have a secondary battery in the boat; the only thing hooked up to it is my backup bilge pump, and the battery has to be manually charged before I go out (it's not connected to the alternator at all). If absolutely necessary, I could get an add-a-battery kit and use the secondary battery to power the GPS, but I'm hoping there is a simpler (and cheaper) solution.
Any ideas?
Thanks,
Jim
Any ideas?
Thanks,
Jim
