Hidden Fuse on 4.3 Tahoe Q4.. Please Help
Status
Not open for further replies.
dmoss8928
Hey guys I'm still trying to solve my no start problem on my 2008 Tahoe q4 w/ the 4.3 Alpha One 1:81. I was doing some research and after checking the 90 amp fuse on the starter solinoid (it was good). I was told there is a 5 or 10 amp fuse on the back of the engine by the power steering cooler? I can't seem to find the fuse after spending 30 minutes in the back of the trasom. Can anyone shine some light on this for me? thanks guys...
I came here because the Tahoe forum isn't very busy haha
David
dmoss8928
Re: Hidden Fuse on 4.3 Tahoe Q4.. Please Help
No one knows anything about it?
achris
More fish than mountain goat
No fuse there. Is your engine MPI or Carb? The MPIs has a fuse block up next to the ECU with the main power relay and the fuel pump relay.. There is also a 15A fuse in the power wire behind the dash, in the ignition key circuit (all engines)...
Do you instruments come on you you turn the key to ON?
Chris.......
dmoss8928
Chris.......
Its Carb and yea my radio, bilage, horn, depth finder all work but thats when I flip my master power switch. All this will work without the key begin turned on
Don S
Those other systems have nothing to do with the ignition system. There should be a 15A fuse in the red/purple wire that goes to the ign. sw.
dmoss8928
Is the fuse going to be under the dash by the key switch or in the back close to the engine?
Don S
Under the dash.
dmoss8928
Under the dash.
If its under there I sure don't see no fuse. Is there a fuse panel any where else on the 4.3s beside of right under the dash?
Failproof
Dmoss, when you cycle the key to the run position, do the gauges respond? Did you have a alarm to indicate the key was on with engine not running(test mode?) If so will it still alarm? How about when you go to the start position? What exactly happens?
Don S
Sometimes the manufacturer builds his own harness, and yes it may be in the fuse panel. Find the red/purple wire on the ignition switch and follow it.
dmoss8928
None of the gauges respond when I turn the key. and I did have an alarm to sound when i had the key turned but no any more. and when I got to start it nothing happens. It don;t even try to roll over...
Don S
With your meter, set to voltage - black lead on a good ground - check for voltage on the B terminal of the ignition switch (red/purple wire). You should have battery voltage there at all times. Key on or off. Do you?
If yes to the above, turn the key to the run position and check for voltage on the I terminal of the ignition switch (purple wire) you should show voltage. Do you?
dmoss8928
I will try this when I get home this afternoon. The back of my ignition switch is a little werid. It has like a squar block with gel type stuff in it and the wires going into the gel, so its hard to get any readings. This make sense?
Don S
It's not an OEM switch, but they all work basically the same, you have power coming into the switch and power going out. What color codes they have, I have no clue. Post some pictures.
dmoss8928
If its not an OEM then what do they call it? And I will post some pics the afternoon after I get off.
BoatDrinksQ5
My Q5 has a fuse box up in there (clear cover)... i would think yours wouldn't be much different. Doesn't seem like they have changed much in the past 5yrs...?
dmoss8928
Yea I have a fuse panel right under the sterring wheel but the wires coming from the ing. switch or going towards the back of the boat.... I have checked all fuses in the panel and all are good..
dmoss8928
In picture 2 there is a black and black / yellow cable that goes right about the ing. switch and they both go to a metal connector not to sure what there purpose is....
Status
