hit brakes,,ligts go out???
lprizman
I just hooked up a new lights system to my trailer,,everything works fine except when I hit the brakes,,light go out,,lift off the brakes lights go back on. I have a Hummer H3, if that matters.
all connections are secure and ground is solid???
any advice???:confused:
thanks
Bifflefan
Re: hit brakes,,ligts go out???
thanks
You still have a bad ground...
lprizman
I connected the ground wire(white one) to the trailer as instructed. I loosened one of the tongue bolts and squeezed it in there,,anythhing else I should do??
thanks for the help
Bifflefan
thanks for the help
You need to scrape the paint off where you make the ground attachment, and where the light grounds attach.
lprizman
will do in the am,,thanks
kenmyfam
Top 3 Causes of Trailer Light Issues.
1, Bad Ground
2, Bad Ground
3, Bad Ground
18Starcraft
I had same problem ended up tapping a hole into trailer and bolting ground into trailer. No problems since.
Knightgang
Remember, the white wire at the trailer tounge is not the only ground connection. You also have a ground connection at each light. On many light kits, this ground is make by the bolt or nut that mounts the light to the trailer. Other kits will have a white wire that has to be attached like the one at the tounge... This is called grounding through the frame, very common on trailers.
Or, you can branch the wire wire at the tounge and run a white wire down each side of the trailer and attach it to the ground leads at the lights. Both methods work...
bruceb58
Honorary Supreme Mariner
Don't do that. Just make the lights ground connection a good one.
Since all the lights go out, its the ground connection between the vehicle and the trailer that is bad. As a test, connect a jumper cable between the frame of the vehicle and a bare metal point of the trailer
hvachillbilly
also check the ground from truck to plug might not be the trailer at all
thanks for the help
Ayuh,.. That grounds the trailer frame,...
But,..
You still need to carry the Ground back to the towunit....
lprizman
Well,,,boys and girls I am proud to admit I am a moron.
And it all started with a good idea,,,I have "goal posts" on my trailer,,,yup PVC pipes,,came with it,,,so,,I no more replacing lights bulbs and mount the lights up high on the post with,,yup no ground.
thanks again for the help!!!!
adding grounding wires now
lance
Knightgang
1, Bad Ground
2, Bad Ground
3, Bad Ground
lance
Glad you figured it out. Sometimes, even though you are SURE you did it all correctly, but it still does not work, it helps to have a few other heads look at it (figuratively) and help fix the issue...
That is what iboats is all about...Congrats...
