Hot water tank?
Shaun78
The liquid to liquid hoses were disconnected. one of the barbs is broken off the tank. Can I use an easyout and just buy a new fitting? Then I will have hot water both ways? The fitting shouldn't be molded to the tank. The others are threaded holes that fittings screw into.
Re: Hot water tank?
Ayuh,......
This is a Boat Repair Question,.......
It's got Nothing to do with Engines or Drives.................:rolleyes:
Don S
Re: Hot water tank?
Moving to Boat Topics and Questions (not engine topics)
Shaun78
Re: Hot water tank?
It looks like the fittings ARE molded to the tank. In that case I might need a new tank
Shaun78
Re: Hot water tank?
ALL FIXED. I took it all apart and connected a hose to the broken part and put in a reducing coupler and now it's allset.....
