Lou C
- Joined
- Nov 10, 2002
- 13,983
Re: How bad is this prop and skeg damage? First Timer
Yes take a boating course
Get a new prop have that one repaired as a spare
Learn how to change the prop put some OMC triple guard grease on the prop shaft, keep spare cotter pins for the prop nut and a prop wrench on the boat
GET A DEPTH FINDER......I have a Garmin 441s GPS/Sounder, it is very accurate and gives a good picture of what the bottom looks like. I boat on the North Shore of Long Island, we have mostly deep water, but 7-8 feet water depth changes with the change from low to high tide so you need to know where you are. We also have rocks, the South Shore has sand, no rocks but much more shallow spots and tidal depth changes (not as much as the North though).
Keep in mind that you have a OMC Cobra, that has not been made for years...if you trash that drive, it's not that easy to find another one...so be mindful of the water depth. Personally the only boat I run without a depth finder is a 10' Walker Bay dinghy with a Suzuki 2.5 hp outboard. And even that one I am going to find a way to mount up removable one.....
