Campylobacter
Thread starter- Joined
- Aug 4, 2007
- 503
I'm going to guess this is the first of many posts here. Sorry for its length.
I just purchased a 1991 Johnson J40TLE. It came on a pontoon boat I am restoring, with no guarantees about its condition. The guy only had the boat for 6 months and gave up trying to get it restored. The one thing he did do was take off the VRO.
Today I decided to give the motor and check to see if it was worth anything. I got it running, but only very briefly as there was no water coming out the tell tale hole so I shut it down. (after disconnecting the buzzer, long story for a different thread)
I removed the lower unit and checked the impeller, it look good but not great so I kept going. Did a compression test, got 140 on the top cylinder, 130 on the bottom. Then I took off the carbs and did a mild cleaning. Put everything back together and tried to start it again, no go. I try to trouble shoot, and I am pretty sure the guy removed the fuel pump when he took off the VRO. I cannot find a fuel pump at all, just a fuel filter where the pump should be, then the line goes straight to a 3 way splitter that feeds the carb and the electric choke.
A couple questions: (I'm a noob that learned everything I know about 2 stroke outboards TODAY)
1. Could I have got this thing started (albeit briefly) without a fuel pump?
2. If I can find the pump in the bucket of stuff he gave me, can you use a VRO fuel pump without the oil as a gas pump?
3. Any other tests I should do before I decide if this motor is any good? and finally
4. How much would you invest in an unknown condition 23 year old motor (I was encouraged by the compression, but still unsure).
Thanks in advance.
Thanks in advance.
