erikgreen
- Joined
- Jan 8, 2007
- 3,105
Re: HUGE PROJECT!! 30' Scarab Sport overhual
Looks good so far. Take your time, and make sure you grind the surfaces down to good, clean glass, with no paint, loose fibers, or wood still attached before re-glassing.
Twin 1708 tabs on the stringers is probably the minimum. If it were me I'd do three layers, or maybe even four. A boat with that amount of power is going to get beat on a lot. The 8 oz cloth adds some strength, but not a ton.
Make sure also you orient the fibers on the two layers differently if you can.. IE if one layer matches the orientation of the stringers horizontally with fibers crossing vertically, try to turn the other layer 45 degrees for more strength. If you're using pre-cut biaxial "tape" this won't be possible.
If you have the hull supported on bunks or five points on jacks, then you shouldn't get warp.
Erik
Erik
