I had a discussion with John from Nauticus about foils and tabs and it's documented in one of the thousands of other threads on this subject. And even he admitted that tabs and foils aren't designed to do the same thing, but that foils are frequently misused and it's why so many people "think" they are of no value. He said yes, a properly set up foil can improve performance. He uses all of the incorrect and misuse experiences to advertise with though.]
You just contradicted your own self. You said that John from Nauticus uses only the incorrect and misuse experiences to advertise with, though you said he said, a properly set-up foil will improve performance.
There site, actually shows what the foils do when properly set-up, not improperly set -up. They really make no claim against them or even other tabs that are also there competetors. They simply "imo" show the differences and where the foil can cause issues in handling compared to there product.
Just like the other tab companies, I'm sure would be willing to point out the differences about their product capabilities compared to Nauticus. Like being able to adjust for a load difference side to siide. I for one, see nothing wrong with that because it simply gives the public knowledge, that they might not have already had to make an informed decision.
True that foils can improve performance when properly set-up, not true that they will perform as well as Nauticus tabs or helm controlled tabs.
Foils can cause very bad handling even when properly set-up, mostly in turning. Like many others here, I have experienced that first hand. I see no reason for someone to sacrifice handling for the sake of saving a few bucks. Instead of improving just some performance, why not get alot of performance increase.
The biggest difference in the foil and any tabs is you can not expect to get the same stability from a foil that is lifting a boat from the center/outdrive. The tabs give you a wider platform as to lift from,unlike the lift from the foil is all from the center of a boat stern, making the teater todder effect even worse than it was without tabs. .02
