i got a freebee to restore she is a 1966
North Beach
Re: i got a freebee to restore she is a 1966
Well it's deff a 66 but someone has repainted it. 66 was the only year with that cabin side window setup but it also only came in avacado green hull and top....
So it's gonna be 1/2" plywood decking and white EPS flotation stock. The side panels should also be 1/2" plywood.
This boat is put together much like mine except I don't have the cuddy. Make sure you save the decking for templates and also the metal seam straps under the decking. You'll need those later.
This will be another good one.
jbcurt00
Good for Dad. Tell him to leave you something to do. Man I like those 60's cuddies. I can see myself in one, twin Johnson 70's, yea man. A little time away from the wife can be priceless.:D Not my wife, I mean other guys and their wives. lol
+1 for all of that :facepalm:
Yeah, OTHER GUY'S WIV............. :rolleyes:
more like +1,000,000,000........... :eek:
jbcurt00
attachment.php
Looks like you owe dad a frosty adult beverage of his choice, maybe quite a few more then 1........ He does a pretty great job of demo!
If he's equally handy on put back, you might consider subbing him out for other work progress challenged Starmadians over the winter :eek:
KRACKERMAN
I need some advice on a couple of things one I have one very small leak from one of my rivets in front of the boat I'm going to try to buck the rivet. Then 5200 it. Two my floor in my boat was floating it was not screwed in at point .nice for removal but I need to know whtat size and length needs to go back. Three should I glovit the seams I'm having mixed feeling on it and foam for floation where do u get it
rheagler
Looks like you and your Pops are making nice progress. I really enjoy working on mine. I actually thought doing the floor was fun.
KRACKERMAN
Ya its giving us a little father son time. He still gives me hell as if I'm 12 years old . But you know its your dad so you give the standard answer YES DAD. Lol
jbcurt00
Buck the rivet, then after getting the hull cleaned up, fill it to about the chines with water, to confirm you've got the leaks fixed, drain & dry, then gluvit the rivets & the seams. Coat-It is an alternative.
I am not to the rivet point yet, so I can't be much help with that, but you'll base the size & grip range on the thickness of ply you use for the deck.
'Most' fiberglass or epoxy suppliers will carry the 2 part pour in foam. You can use a few different products to seal the wood work (deck & side panels etc..) if you use epoxy, get the foam at the same time if possible. I will be getting my fiberglass & epoxy from either US Composites or Composite One. Depending on where you are in Maryland, you might get lucky & find a local supplier for the epoxy. In 55gal bulk, some shops will sell you some of their resins, at a profit for them, but for less then you could buy it. But Composites One will probably be close to you, as they are to me. And except for the 'becoming a customer' paperwork & registration hassles, they are a bit cheaper for me then US Comps, but US Comps pretty much beats the rest of the suppliers I checked, shipping to me in WV.
KRACKERMAN
Going to be sandy down the seams for a nice coat of glovit
jbcurt00
Rivets too ;)
KRACKERMAN
You mention coat it is this a better sealer JB
jbcurt00
It's just another product some have used. Some like 1, dislike the other.... Chevy~Ford
Mostly it's the $, Gluvit is higher. Use the Advanced search feature from the SC owner's group homepage. It should find some threads that used each 1. I have not yet used either. I have agreed to sell my Jet, unfinished, to my boss. And until I get that motor started, and sell it to him, I'm not getting the next project brought home from storage, in the driveway & underway.... But based on the # of favorable comments across several threads, I'll be using Gluvit. Because unless I continue to hoard tinny's, I won't need the gallon kit & the Quart will do my hull for what I deem a reasonable price.;)
Google Gluvit vs Coat-it, it may find other comments on other forums. At this point it's all research. Amass all the info you can & sift thru it to see what will & won't fit w/ your budget, needs, ability & etc
trafferty
Well this is not starting out 2 good now my pictures are up side down. Lmao well I got them on here.
You could have just said you were really from Australia! Would explain them being upside down... :eek:
Welcome aboard!
KRACKERMAN
Lol I still don't have the picture thing down yet. Lmao
KRACKERMAN
ok pops and i started early to day we bucked the one rivet that was leaking and started sanding the seams and rivets as we cleaned the seams we notice that there was a thick glue type stuff in the seams. we believe some one has allready treated the seams we top our operation and filled the boat with water we are going to let it set till tonight if it dont leak we are not going to pull it out. what do you guys think. p.s. we fixed the rivet that was leaking
kfa4303
Banned
Sounds good. No telling what the previous owner(s) may have done to fix a leak in the past, but Silicone is a no-no. I would try to remove it as best you can before you apply the Gluv-it. Keep us posted.
ctriverfish
Before you empty the boat try to clean the junk out from under the ribs. I used a piece of tubing attached to a air hose snake the tube under the ribs from one side or the other and give it good blast of air you will be amazed at the junk that will come out. I took me a wile (10 or 12 times) before nothing but air cam out of each rib. Good luck and you are doing a great job.IMG00056-20120526-1436.jpg
