I/O (Sterndrive) Conversion to Outboards
tpenfield
Guess I'll have to take you word for it. Being 2X the force than I don't see how the Crap --- arrel stays together going from a SSX 30 to a 280 OSX. I have no stringer extra anything inside the boat. Sure my 280 only has a 25.5 ft hull
Than we can compare the Formula 310 sterndrive or OB, the interior hull is the same less the holes going to OB
Here is the difference in those 2 boats (Formula 310 I/O vs OB)
The outboard version has the hull extended at the full height of the transom and distributes the load to the outer areas of the hull. (actually a clever design)
The I/O version does not have the hull extended and is transferring the forces more directly to the stringers. So, if you took the I/O version and converted it to OB's you would have to/want to add the support braces, as is the case with most conversions.
Ted, since you ran these past the naval architect, I would say, keep with the current plan.
tpenfield
Transom support structure is roughed out.
Now onto the final grinding . . . Oh joy . . . :p
My cordless angle grinder is being put to the test.
Pmt133
Love cordless tools. Had to go to air for mine as I kept burning them out. Obviously you have a wee bit less grinding to do than I did though. :LOL:
I have a 35 year old "Craftsman Pro" angle grinder which is a DeWalt with a black housing and Craftsman labels. its corded, and has gone thru 3 sets of brushes, a cord, and countless spindle nuts and backing pads to date. it has rebuilt 4 boats, and about a dozen hotrods over the years.
the cordless ones I used have all come and gone, however that old craftsman is a workhorse.
Pmt133
That's like the black and decker rotary buffer I have... thing is like 50 years old. Buffed every boat dad owned and I pulled the brushes out of it last year thinking they may be due and slapped them right back in because they weren't even half worn. Probably out last any replacements I got too.
Gives you a hell of a workout using it though.
tpenfield
I have both a cordless and corded angle grinders. Running 40 grit flap disks.
Progress so far . . .
I've been using the cordless, since the corded goes too fast. I was getting a lot of static electricity as I was grinding, which I was not too keen about. I kept a mist spray bottle handy and that has helped.
Not sure if other folks have experienced static when grinding and have any tricks/tips to share.
tpenfield
I made the mistake of touching an area of the fiberglass that had been ground . . . ouch . . . microscopic fibers in my finger :oops:
I used the Hull & Deck putty to set these pieces of the transom support structure in place.
OMG !!! :eek: . . . It's warm enough outside to have the resin cure on its own! :D
