Re: I'm an owner! 1975 Islander 22
Happy Motivation Friday to the Starmada!
I "Tom Sawyered" the boy into sorting the huge pail full of almost every screw, bolt and nut that I removed from the original boat. Here he is, blissfully working away, totally unaware that he was suckered.
After getting the console wrapped in glass (great idea EZ), sanded down, painted with one more coat of epoxy, painted black (helps me see what I'm doing when sanding) and sanded down again....
Then I brushed the console with the same grey porch paint I put on the walls and transom wood. This probably won't be the final color for the console, it still needs to be sanded down a lot more and there's that void on the left side near the bottom that I gotta fill. But it gives it a semi-finished look for now. Remember, my only goal at the moment is to get this boat up on a plane before I have to winterize it. Next year can be about making it pretty.
I mounted up the stuff I have for the console, and screwed it to the wall. None of it is wired up yet. Well okay, I did get the steering hooked up. There will eventually be a six gang switch/circuit breaker panel to the left of the wheel, and a stereo to the right of the VHF.
I almost had the gimbal and transom plate mounted and tightened up the other night and thank goodness I stumbled across this thread:
http://forums.iboats.com/showthread.php?t=443365
Realized I'd forgotten this shim plate. ARGHH!!! So that cost me an extra day to go home, cut it out, CPES the h**l out of it, wait for it for to set up overnight.
Last night the boy came back to the boat with me again and we got the shim plate in and all the bolts (except one) installed. I *THINK* I may actually be ready to plop the motor in tonight.
But I just know my conscience is gonna make me pull the floors back out and wash out the dead leaves and clean off that filthy transom plate first.
Or maybe I'll just drop the motor in and go fishin all weekend.
We'll see.
Now call in sick, grab your tools and get to work on yer boats!!!!
