Tried the fasco in the gun today ,it worked for about 5 seconds then not so good.Putting it on with a brush is pretty fast actually.A gallon is plenty of sealer to do inside and out!Mine is the clear version and if i had to do it again id get a minor tint for the simple fact that wihen you step on it because you dont see it,it can almost kill you,lol
SHSU i used a brush.,mixed up about 2 1/2 cups worth.Spreads easily,on the day i did it ,it took hours to start to really set (humidity maybe).They say 15 to 30 work time so i only mixed enough for that expectation.After i go for blood tests today im going to look at it as yesterday i had the boat covered for the weekly monsoon.The picture here shows the gluvit on the rivets in a yellowish tint and the fasco clear.![]()
I went to the local dollar store and bought 2 sets of betty crocker measuring cups to use with the fasco and medium sized plastic containers to mix it in.Total cost about 5 dollars.Why 2 sets you ask?This way you dont mix one material with the other in their original containers.Both containers were pretty full when opened but theres enough room to just leave the cups in their respective containers.The closest i can compare the fasco to is think of aunt Jemima syrup!
For future reference putting gluvit or fasco on the rib rivets is a waste of time/product, you can't get the goop around the rivet body where water would penetrate the hull. Seams, keel and the rivets in the field holding on the strakes are the only rivets it's effective on. Yeah I slathered that stuff all over my first boat resto and somebody mentioned it to me. :lol:
Not sure if you could see in any of my pic but my seams have a molasses colored whatever slathered all over.Any of you other starcraft guys have that also? My seams are 100 percent tight.
Started to put some of the floor in.I measured exactly on what was in there for the wood.So you can imagine my shock when the wood seemed short in width.DUH! i forgot about the side panels i have to rebuild and the bottom pieces of l shaped alum that screws in the floor .All is good.So i gots to go buy a sheet of 1/2 spruce 4x8 ply.Shsu sorry 3 cups total and you can so a lot!As for the rivets that Watermann said i didnt have to do if i didnt do them they would of felt left out and maybe got revenge on me by poping out later,lol.Better safe than sorry![]()
Each piece was 61 wide by 48 long.The 2 channels you see were put back in with 3/16 blind rivets.Im going to screw the floor not rivet for easy removal if need be.Ive got a severe case of laziness today though .Still have to clean and fasco the underside also.
I'm gonna chime in with the other guys. My recommendation is to not screw the deck down. Use rivets instead.Each piece was 61 wide by 48 long.The 2 channels you see were put back in with 3/16 blind rivets.Im going to screw the floor not rivet for easy removal if need be.Ive got a severe case of laziness today though .Still have to clean and fasco the underside also.
Will take riveting under advisement.SHSU heres the directions.
