juicebox
- Joined
- May 27, 2009
- 82
i have an old bayliner admiralty 1977. i picked this two years ago knowing that it had some damage to the keel. this boat doesn't take on much water. i've had it out on erie many times. i want to address this soft spot this year. where the keel sits on the foward most roller it presses in about an inch to inch and a half. i want to do this as cheap as possible. it doesn't have to be pretty. my thoughts are to cut a hole in the deck grind down inside a little, clean with acetone, and use 4 layers of biax with epoxy on the inside. clean and grind down the outside and go with two layers of biax and epoxy. maybe then just hit with some bottom paint and be done. Does anyone think this will be sufficient? if not, any opinions or help would be appreciated. i also plan on adjusting the bunks on the trailer so there is not as much pressure on the roller. thanks.
