Love, Necessity and Pride
Status
Not open for further replies.
Woodonglass
Re: Love, Necessity and Pride
Enjoyed the conversation and getting to know you. Let me know if I can help with anything...Anytime!
GT1000000
Nice job.... Now get crackin on the glassin'....
.... Seeing that boat without its guts really shows you how wide a beam (relative to height) those bass boats have...
Look forward to the next steps
Thanks...actually did some glassing today...hopefully it doesn't come back to bite me...[see explanation below]...
Speaking of beams and guts and height, I resemble those remarks...LOL...
Yessir, me too, and thanks again for all you have done and all the great information and assistance you constantly provide us knuckleheads...I am very excited to see the Flamingo get its feathers wet...here's hoping that pans out this weekend...the engine sounded ready...
And, speaking of wet...
My first actual foray into fiberglassing was a fair to midland success...let me 'splain...
set up a little pop up shelter, mostly to keep the heat off, got all the basics set up, and glassed in the bilge drain backer plus plugged up a couple of no longer needed drain holes...
The holes were thoroughly cleaned with acetone, the holes were backed up with good 'ol duct tape, several little discs of CSM and 1708 were cut to fit the holes and build some thickness, and a couple of faired layers, progressively larger of CSM and 1708 for strength were all glassed in...
They turned out solid as the surrounding hull...very happy with the results...
Then the bilge drain backer got slathered in my very first batch of PB, smooshed into place, and a little filetting around the edges... [this is the same piece that I fiberglassed in post #386, pic #5]
See that shiny wet lookin stuff in the picture above...
The Rest of the Story...
As you can see in the first picture, it was all bright and Sunny and warm and No Rain Expected!!!
Well of course as I am sitting there admiring my work, the skies start to darken up, I scramble to get everything under cover, but it was toooooo late! The skies opened up with a vengeance and by the time I got most everything indoors, my can of chopped fibers was pretty much soaked, and in less than 10 minutes, there was water half way up the transom, with no place for it to go...remember, I just plugged all the lowermost drain holes...:mad:...
So it rained, and rained, and rained for the better part of an hour, very heavily, I might add...and by the time it stopped, even the few holes left in the hull, were no match, water was pouring over the top of the transom and all the remaining hull perforations...kind of looked like the fountain at the Bellagio Hotel in Vegas, although not as pretty or choreographed...
I raised the jack all the way, got about 50% of the water out, then I broke out my recently aquired wet vac, and filled it 6 times [its a 14 gallon size], to get most of the water out [Note to CC254- now I know it could definitely work as a hot tub]...
Well to make a long story longer, it has been spittin and drizzlin off and on since, it'll prolly be full of water again by morning, after which I hope I can get it dried up, the "NEW" piece I installed isn't saturated, and I can get a new drain hole drilled out and sealed with resin...
This has been my fear of starting on the fiberglassing from the beginning...with no proper shelter, I will be running this risk of getting drenched right in the middle of a major lay-up...I am trying to figure out a solution, but they all cost money...something I am not too close to, lately...but in the end, I will prevail!
Hope y'all are havin a fun and productive weekend...
Happy Thoughts...
TruckDrivingFool
Bum deal GT at least you got a couple things done and now you know it doesn't leak. :D
Woodonglass
Go to HF and Buy a 10 x 20 ft tarp. Go to lowes and buy 2 10' sticks of 1" PVC and 10 90's and 10 22.5? elbows and make two of these
(hope you can understand what I'm trying to draw)
You can tent the boat in less than a minute. tie the coreners and the water will Run off her.
GT1000000
I think I got the Tent Stands all figured out, but just want to double check something...
Where the PVC intersects, those should be Tees, Correct... or am I missing something...
Thanks...:)
Jon Sob
Wow GT ... I am glad you can see it ... lol. I'm stumped.
Woodonglass
Thanks...:)
DUH!!! YOu caught me!!! You are absolutely correct.
Woodonglass
I made these Portable Seat Pedestals, Kinda like what I'm talking about. Built it for less than 10 bucks
Trooper82
Bummer on the rain right in the midst of your glassin', but hey it looks real good!
You think it is going to have to be redone?
I'm going for a hoop house type construction on my next rain cover. The current one is falling apart. Everytime it rains I have to go dump out the sections thst fill with water.
sphelps
Sorry about the rain that must have been some down pour ta fill it up like that!
I read blue prints every day at work . Woods shelter drawing even has me baffled a little. Maybe I ain't got my head turned right or somethin!:D
GT1000000
It amazes me the never-ending structures that can be done with PVC...
Yeah, I am hoping that the wood was sealed up enough that it didn't get saturated...I'll know more in a few...
Still trying to work out the shelter construction...for now I might set up something down and dirty, similar to "WoG's" idea, that I can just throw together quickly and cover the boat, then try and work out a way to set up something a little more semi-permanent, that won't cost an arm and a leg, and can be dismantled when the project is done...
You know the gator gushers, frog flushers, and bird bashers we get down here in the 'sunshine state'...6, 8, 10, inches in two minutes, then its over, then, when I get up this morning, it looks like I am in the midst of the Smokey Mountains...fog, everywhere...sheesh...:facepalm:
To figure out wood's sketch you have to hold your left eye to the right , your right eye to the left, do the boogie-woogie and shake it all about...:D
fat fanny
I don't want to doubt Wood but shouldn't the structures front coners be just 22.5's and not 22.5 & 45's ? Very good idea and cheap. I like the stools
jbcurt00
Hopefully there was just enough time for cure to start before the tub filled up.....
If the wood isn't wet, will the resin blush, like waxed resin does? Just need a light sanding to get a tooth & remove the blush?
May the sunshine state provide it's namesake for you and dry out all the glass & resin sufficiently to proceed w/ some more layups today.
GT1000000
Thank goodness, yes both applications had kicked off, just hope it didn't get to the one, single, solitary piece of wood...:facepalm:
And yes, it did blush like it was going on its first date, but it seems to have cleared up...
Can't do any more lay-ups today...Three reasons...
1-Spent all morning setting up a temporary shelter...
Getting my little utility trailer tires aired up, loading the cap on it, and moving it to the back yard...
and my fishin buddy just called and said the Bluegills and Warmouth are bitin...so I am gone fishin...
Hope evryone is having a great weekend, may the week go quickly, so we can all get back to work on our boats...
L8R...:D
PS- if I don't eat the fish I am going to catch before taking any pics...I'll be sure to post em...
jbcurt00
BBE, makes his return!:D
I was thinking the BBE*2 (squared);)
Hope you catch your limits. For bluegill what is that in FL? 1000?:eek: Enjoy!
If we don't enjoy all the other stuff going on too, the boats are carrying a lot of pressure to be fun to 'work on' & be a useful break.
Glad the GLassassin :)facepalm:) work was sufficient to stand up to the deluge of rain.
I can 'see' your cup runneth-ing over when the hull filled up & all those rubrail screw holes spouting like a fountain in my mind's eye. Too bad no video, I'd watch it, & probably drop a clip in your thread like CBK did his 'Dancing Islander' gif on Jas's build.:cool:
sphelps
Agreed , seeing the fountains skeetin out the hull would be kinda cool in a sick way! Maybe when he gets back from fishing he can throw the water hose in there and make a vid for us!:cool: :D
GT1000000
Glad the GLassassin work was sufficient to stand up to the deluge of rain.
Yep, I'm still old school, don't have a vid recorder...altho the picture taker has a video button on it...hmmmm, gonna hafta give it a whirl sumday...
Yes, the new and somewhat more improved and sophisticated BBE...
Hopefully that will never make its way on this thread, with the new temporary BBE...I hope to not have this hot tub filled any time soon, again...
BTW, as promised...
According to the fish finder, tons of fish swimmin under the boat...they just ain't hungry for our bait...guess they have too many tasty sushi to choose from...
anyhooo, caught a couple of keeper Bass...
and I got home today after work inspired to do sumthin, so this is what I did...
Transom plate with its first resin soak and 1 layer of CSM...Yes, this is the side that you will always be able to see...
Hopefully tomorrow, I'll coat the other side and actually get ready to permanently install by the weekend...
Yep, actually kinda excited to get to this point...
jbcurt00
Nice couple of bass
Nicer transom plate:cool:
Congrats!
Status
