oops!
- Joined
- Oct 18, 2007
- 12,932
Re: Man vs. Boat (season 1).
as far as the clamps.......use the thru holes that you allready have. the transom hooks......the key hole.....the garboard.....and knock a few more in for good measure.
really....dont worry about it.....you are going to have to do some glass work back there any how.
as far as fitting the transom.....you can cut down the top edge with out loosing the integrity you need. as much as 5 inches from the top of the key hole.
you can also shave an inch or two from the bottom v and use 2 pieces for that. fill the edges with peanut butter, and glass the whole sha bang.
the only thing is that you want good wood around the key hole. (i know you dont know where that is right now....but if you are really worried.....you can set the x dimension right now . just take your measurements from the outside of the transom)
if you knock the bottom off........this will help you know that your transom is sitting right.
the most common mistake in transom replacement is that the ply does not reach the bottom correctly, and there is a space between the outer hull and the bottom of the transom.
just remember.....after your new transom is built......before the install......practice putting it in......5 times....place.....bolt....
do this till its automatic.... leave nothing to chance.
the "act" of placement. is one of the single most important things in your boat......stringers can be glassed. but there can be no gap between the transom and the skin.
