Last year, I bought myself late 80's Regal Medallion 195 at a great price because of a cracked engine block.
Not knowing much about boats, and having a very strong automotive background, I bought the boat. Since then I've marineized a 4.3 Vortec and installed it into the boat with a heat exchanger.
The boat ran very well, managed 62 MPH (GPS) with a 23 pitch prop. And because I retained the vortec automotive fuel injection, fuel efficiency and engine performance (idle, ect) were perfect.
The only actual problem the boat had was a shifting problem (hard to shift to neutral).
Eventually, the engine coupler failed. After doing some research, I went shoping and starting removing my stern drive.
I got a new coupler with a new spline shaft, a shift cable kit and a stern drive seal kit (bellows, ect) as well as new senders and new u-joints.
In terms of taking everything apart, I'm now stuck at the gimbal ring.
I was not originally planning on removing the ring, however, I have noticed two issues with it.
1. There apears to be some play at the top hindge pin. You can move the gimbal ring roughly 5 degrees ether way.(play in the stearing)
2. The ring also has up/down play. I believe there are some seals or bushing missing from the bottom hindge pin area.
Research on the gimbal ring play is alot harder to come by on the internet. Is this play "aceptable" or should I be removing the ring and replacing the lower bushings and the upper pin?
I will be removing the engine (Again) anyway, to retrofit in the new coupler. So now would be a good time to do it (rather than having to do the drill and plug method)
Also How do I remove the lower hinge pin? I got the cotter pin out no problem, but the pin itself won't budge. It apears to have a slot screwdriver slit in the bottom. Am I suposed to turn this? or hit it with a hammer? All manuals just say to remove it.. but how? Maybe mine is "rusted" in... Is this common?
Also, I know boat parts are expensive but is the upper pin really 250 bucks? It's like a 4 inch bolt with some square sections in it.
