- Joined
- Oct 25, 2011
- 25,328
Re: MFG rebuild getting started pics
All the shows that follow paint work on auto/truck have 'bake' booths to speed the cure of the paint. UV? Temp? Both? Sorry, cant be of more help. But at 70, it may take 2 wks +/- for full cure..
I'd think no compound for sure on fresh paint.
This came up under a google search: boat paint cure time wet sand buff DIY
The paint you used may also be 'designed' for a certain gloss level & polishing/buffing for a boat show shine may not produce the expected results.
I'd call Vlaspar's (?right?) help line & ask them. Depending on where in the US, they may still be there tonight.....
Try to PM WOG &/or GT1M so that as soon as they log on next it'll hit 'em....
Do not sand or buff Interlux Perfection if it's cured more than 2 days at 73 degrees.
Interlux gives max times for sanding:
"Apply 2-3 coats of Perfection (depending on color) following the proper dry times. Perfection may be applied by roller and brush using the roll and tip method. Sand between coats with 320-360 grade (grit) paper. Remove sanding residue with a rag dampened with Brushing Thinner 2333N. If maximum times are exceeded, sand with 320-400 grade (grit) sandpaper. For the best results it is recommended to sand between coats."
If you attempt to buff before final cure you REALLY need to know what you are doing so sanding is the preferred method BEFORE cure and before the final coat..
As stated by others Perfection is similar in it's cure characteristics to Awlgrip.. Once the final coat is cured do not sand or buff or you'll need another coat..
This stuff is not intended to be buffed after cure and Interlux will tell you this. It really should be in the instructions but it's not..
