1993-1995 4.3L remanufactured marine engine (one piece rear main seal, roller cam and roller lifters). This motor has been professionally remanufactured to meet or exceed GM OEM marine engine stock specifications.
michiganmotorz.com
this is what you have, the adjustable valve train used on millions of Chevrolets, see the rocker arm that pivots on the stud, how tight you get the adjusting nut, determines the adjustment of the hydraulic lifter. This requires that you follow the GM procedure to set all 12 valves.
Michigan Motorz: your one-stop online shop for new & remanufactured marine engines, parts & accessories. Fast shipping, expert support worldwide.
michiganmotorz.com
this is the later series, the Vortec, look at how the valve train is different, on these there is no provision for adjustment. This is the set up where you can simply torque the retainer to 20 ft lbs.
Most Chevy enthusiasts seem to prefer the older set up due to the adjustable nature of it, with the newer system if you get valvetrain noise, other than replacing parts there isn't much you can do.
