my stringer job 19' Cobia with pics
1cobia
I have the deck,foam and far right stringer removed.
Can I sister a new stringer next to this one or should it be removed.
This is the stringer channel with it removed.No bedding from the factory?
maxum247
Re: my stringer job 19' Cobia
Outboard or inboard hull?
1cobia
Re: my stringer job 19' Cobia with pics
I/O V6 Merc
83mulligan
i'm no expert, but i think i know what the experts are going to say..............
1cobia
yup,me to just dreamin
maxum247
A new stringer would be best, your in there and have done all the work to get there, with the work you will do trying to sister everything you probably won't save a lot of time and the old wood will be there as a failure point in the future and may even encourage the new wood to decay quicker.
Use your safety equiptment!
Protect your lungs, eye's and skin with a respirator, goggles, long sleeve shirt, and gloves while grinding, vaccuming, sweeping, etc. max!
1cobia
That is what I was wondering about I don't want rot transfering over to the new wood so out it comes and yes Iwear respirator,safety glasses powder
and tyvec suit.Next question will be about hull support,while taking the stringers out I want to brace the hull while on the trailer so I can pull it out of the garage to do the grinding and back in at the end of the day.
Should I do one side at a time or take it all out at once?
s1120
Your layout looks alot like what I am working with on my 20' Rinker. I will be keeping a eye on this thred to see how it goes!
1cobia
Hi s1120 my boat is a '91 cobia 19 foot my center gas tank also had a removeable floor panel under the carpet just caulked in but I figured it was just a previous owner cut it out to work on the tank and did not repair the floor whe done.PS that is where my stringers had rot also.
maxum247
Probably would be better to do one stringer at a time as the boat will be moved in and out of the garage, brace the hull so that your comfortable, "probably" not too much of a worry, but as the old saying goes "better safe than sorry". max!
1cobia
Did lots of grinding this weekend almost done.
Marine plywood has been drying 2 weeks.
Resin glass and other materials.
1cobia
Update pics Stringers are cut,one bulkhead cut just need to cut one more
and some cross bracing.Then its peanut butter jelly time!
JaSla74
Looking good. I'm curious though, what conditions is the deck in at the bow?
1cobia
Its all dry and solid I can see the inside of the compartments and its dry in there too.
1cobia
new pics started glassing
maxum247
Glad to see your making headway, looks good! :)
I went backwards on my project today.:(
max!
jcsercsa
Looking good there 1cobia, Nice work glad you decided to take out that old stringer !!! did you take a core sample of the motor mounts ?? John
s1120
Looking good!!
Hard to see but do you have a drain chennel into the bilge from the fueltank well?? [it is a belly tank right??
Im keeping a good eye on this, becouse your layout is almost the same as my 20' Rinker.
1cobia
motor mount samples were good, nice solid wood.And yes there is a drain hole in tank compartment just can't see from the pic. Thanks for taking a look.
