Need HELP identifying motor first
jimmbo
Idle speed is set in Gear, under load, and is generally 600rpm, give or take 50rpm. 1100 in Neutral, will do a lot of Damage to the Clutch Dog, and Gears.
Do you have the correct Factory Service Manual for the Motor? If not, get one. It will have the correct Specs and the process of the Link and Sync.
The Carbs are both fully closed at Idle?
A 2 stroke in good condition will idle at 700 RPM all day long.=====Post the actual compression values here.
Dalejam
I don’t want to jump all over the place on this topic . But can someone post a picture or the book number that should be using. So I have a fuel water separator just before the motor. Gas is fresh . I am scratching my head a lot . I will post compression numbers
