Need internal engine parts for Gale Sea King 1962 15hp 2stroke
aeviaanah
Need internal engine parts for Gale Sea King 1962 15hp 2stroke....any ideas?
I need
crankshaft bearing
gasket kit
piston rings
F_R
Honorary Supreme Mariner
Re: Need internal engine parts for Gale Sea King 1962 15hp 2stroke
Even before those items, you need a parts book. Once you have the part numbers, go to www.marineengine.com to see if they are available.
Top main bearing is part number 377528
piston ring set is 378416 (3 rings)
There never was a gasket set. You have to order individual gaskets.
twocyclemania
Another alternative would be to find a decent power head and save yourself all the work and hunting down parts. Just swap it out. May be cheaper too. Keep an eye on ebay or ask around and you should be able to find one. Also, I believe the block is the same as one used on mid 50's (55-56?) Evinrude 15's.
twocyclemania
Just noticed that there's a 15 Evinrude (1956) powerhead on eaby for $49 with $25 shipping. I believe that is the same as yours but I'd ask the question here and with the seller to be sure if you're interested. fyi good luck!
aeviaanah
I actually need the connecting rod bearings, not crankshaft, sorry.
I was looking through part numbers and I dont see a Gale anywhere, that is who made Sea king in 1962. Looks like you referenced Johnson/Evinrude parts....are they the same or something?
If so, how can I be sure they are the right part? The search engine does not recognize my model number either. Where did you find the 3 ring piston set? Thanks for your help.
Id have to be sure that the block is truely the same from 1955-1962. I am very new at all this and am trying my best to not waste any money or order wrong parts. Should I have left piston rings on the cyclinder? The guy helping me told me to replace them. I listened, took em off and they broke.
There is a Outboard sea king on craigslist about 2 hours away. Looks identical to what I got, hes asking 80. Ive called him to ask for a model number so I can track the year down. Havent got a call back yet.
twocyclemania
Here's a couple of places to find out if the 15 Gale and older 15 Evinrude are the same (I'd put money on it they are). Google 'Duckworks' and Max Wawrzyniak (odd job motors) and ask them or start a new post on iboats with the question and you'll find out for sure. I think that's your best bet. The only difference I can discern is the rubber cushions for the metal cowling on the old Evinrude. Good luck!
F_R
Ahem....I think I said get a parts book. That will tell you what parts are the same and what are different. Send me a PM with your e-mail address and I'll help you with a book. I'll need the model number because there was more than one 15hp that year.
The connecting rod rollers set is 378151 (for one rod), and the rollers retainer cage set is 203244 (for one rod).
Are those rollers rusted because water got in through the lower crankshaft seal?? Seal is 303804.
If the Gale part number is the same as the J/E part number, the part is the same. Gale Products was the division of OMC that made motors for others, such as Wards. Johnson and Evinrude were other divisions. And Cushman Scooters and Lawn Boy mowers and Pioneer chainsaws, to name a few.
aeviaanah
Thanks for the references! Ill go take a look over there for whatever information I can find.
PM sent, thanks for your help F_R...I will be replacing crankshaft seal as well. Thanks for the part number. The motor was sank twice, water found its way in somehow.
Heres an update...
Here is the internal motor after Ive spend some time freeing it up.
http://www.youtube.com/watch?v=-oQBHUxND5Q
The pistons...
http://www.youtube.com/watch?v=b5rFLXXlrj0
When this motor was given to me the airbox was empty, should there be some kind of filter in here? If so, will marineengine.com have it?
F_R
Nothing goes in the air box. It is a silencer, not an air filter. There isn't much dust on a lake, so no air filter is needed.
e-mail sent.
aeviaanah
e-mail sent.
Thanks I noticed that In the parts manual.
1946Zephyr
It was sank twice? WOW! It sounds like the thumb screws need to be a little bit tighter on the transome. :D
MahtyMaht
Or the loose nut between the throttle and the boat should have been replaced much earlier.
aeviaanah
Yea the guy before me sank it twice hah! Its in great condition tho, he didnt even attempt to fix it after the second sink it seized up on him and he gave up. This motor has been through some abuse but is still in great condition.
1946Zephyr
Hey, it's a Gale. One of the most abused motors on the planet and still one of the best. Gales are like old Ramblers....take a lickin' and keep on tickin' :D
aeviaanah
Thats good to hear I got a good motor.
I got all my parts ordered today...after honing the cylinders, is there anything special required to installing piston rings? Just put em on and call it good?
F_R
Don't break them. Seriously, put them in the cylinder bore first and check the end gaps. Receiving the wrong parts (oversize rings) is rare but not unheard of. I'm looking for the gap specs, but haven't found it yet.
EDIT: Found it. .007"-.017"
MahtyMaht
And arent the gaps suppossed to be staggered?
aeviaanah
Thanks FR. Ill be sure to check the end gaps before installing. I also need to hone out the cylinders first.
The gaps are staggered 180 degrees apart.
aeviaanah
Is there a timing adjustment for these old outboards? If so how is it done?
1946Zephyr
A lot of pistons from what I have seen, will have pins in the groves, to locate the ends for you, so yea. Even without the pins, I try to stagger ring ends 180 degrees from each other, on each joining ring.
