VaGent
Thread starter- Joined
- Jul 14, 2008
- 221
I have a 1986 70 HP Johnson outboard that I am told needs new rings do to low compression. I am also told that the carbs on my engine have fixed needle valves whereas the new engines (1995 & up) have adjustable needle valves thereby allowing for a much better setting. What I am interested in doing if it is even possible or makes any sense is to try & find the newer carbs & rebuild them & install them on my engine if I decide to have it rebuilt.
Does this make sense to do to an older motor or should I just leave the carbs like they are. If it "IS" possible & makes sense, where would I go to find "used" or "new" carbs that would work? Any help or advice would be greatly appreciated. I am using the Johnson 70 on a 24 ft pontoon boat I completely rebuilt last year but the engine doesn't want to idle below 1200 rpms unless it cuts off. The mechanic I went to said the compression was low (#1=123 #2=125 & #3=130) & that was way it would not idle lower. He is talking about rebuilding the power head to fix the problem. I was also told if I had the carbs that had the adjustable needle valves that would be a big help for the engine. Since I am not a marine mechanic I really don't know the answers.
And advice or information would be greatly appreciated.
