I was asking how to view my replies to threads that i was not subscribed to.
It's automatic unless you changed it before . . .no, it is not automatic, you have to go into your optons and make it automatic.
Don't do that . . . Just click your user ID or "My Profile". Click "Find all posts". DoneBut doing an advanced search for posts made by me (the manual way to do "my replies") does nto work either. It only has posts from more than a year ago.
So at this point can we assume that the horizontal picture scrolling "problem" is going to stay? In my resto thread, I intentionally made wider pictures, being guided by what was then the available width, so they would show more detail. As I stumble through my project, I'm hoping that the record of it might help somebody in the future who knew as little as I did. If they have to screw around with scrolling side to side to see the photos, I doubt they'll bother reading it. It woud be a major pain for me to go back and edit all my photos to max. 640 wide.
Is that the alternative?
EDIT: This seems to only be a problem using Firefox. In IE, using the most magnified setting View>Text Size>Largest, it seems to be OK.
If your monitor settings are set at 1280X1024 for the screen resolution then there is no scrolling for the photos. Myself and a few others are using that resolution and the forum appears fine. There is no photo scrolling and everything fits fine.
It's only changed if you elected to upgrade. It is not some sort of requirement . . .
iBoats elected to change to a different version of vbulletin. Not every forum that uses vbulletin will necessarilly want or feel the need to upgrade. Up to the site owner.You lost me on this one. What are you referring to?
This is a suggestion, not a complaint. (and a repeat of a suggestion to boot)
If the tech guys put the user avatar and stat panel "ABOVE" the post instead of to the left it would make the area to view the post wider. I know it can be done with this version of the software because I have seen it on other sites.
I know I'm not the guy who sets policy for Iboats but I really hope someone considers this suggestion as it will really improve users with lower resolution screens be able to enjoy the site again. I just used the zoom in feature to see what others are complaining about and it really is quite bad viewing the site with lower resolutions.
