Re: Older boat questions ...
Ok I think I'm too late but you were asking on the second page how to shape your stringers. I have seen where the old stringers are basicly dust from rot. If this was the case you could have taken the top fiberglass off then cut the bottom of the side fiberglassoff clos to the deck staying the same distance from the hull and used the old fiberglass as the pattern for the bottom of your new stringers. Then all you need is the amount you left on the hull and add that to the topp and you have the exact stinger. Like George said, the drain holes should be at the aft of each section. I have seen some of the guys here take PVC, cut it in half long ways and tape it to the hull before you foam in everything. This sounds like a great idea you would just have to split 90's and 45's and elbow's and glue them to your PVC to ensure there is no foam leakage into the pvc. I am going to follow along and see all the input by the guys that have more information than I do. I will be really digging into my 83 Dyna Trak in a few weeks to have her ready to glass as soon as it warms back up.
