Now as you can see
I am NOT trying to eliminate "PB" from the forums. Not at all. ..
Again. .. Let me try to explain what I am trying to suggest.
Use the Term "PB" all you want .. however it would be helpful to
Define exactly What Filler components will go into the "PB" that you are suggesting to use.
Examples:
Q. How do I help tab in my stringers to avoid small pockets of air.
A. Mix up some PB and use as a fillet. ( Not really telling you What PB to use ).
Q. Whats PB ?
Q. I have some stress cracks and I would like to know whats the best way to repair.
A. Mix up some PB then sand and apply gelcoat. ( Again not really telling you What filler to use ).
Q. Whats PB?
Now typically the answer to "whats PB" is done by redirecting the thread to another thread with a recipe on how and what to mix. We let X,Y,Z member explain what "PB" your talking about Via another thread link.
How about something more direct .. like this .. If you want to use the "PB" term.
Q. I have some stress cracks and would like to know what is the best way to repair.
A. You should use some PB ( resin mixed with cabosil and possibly some csm ) depending on how extensive the cracks are.
Q. Im ready to glass in my stringers now .. what else should use to help in the glassing process.
(A. You should have already done your homework and know what you need
. Im kidding now
A. You should apply some PB fillets making radi between your stringers and hull. Depending on the size and length of the stringers you could use cabosil and resin or a fairing filler like micro bubbles ).
As you can see there is more information in the second like of questions and answers than the first.
I think being a little more specific about what kind of PB will help the question rather than possibly creating more questions about PB.
Continued use the term PB is fine IMHO .. but it might be better if you Explain what components go into said PB if your going to use it. We all know its a filler of some kind .. but What PB is on your mind when suggesting it.
As of right now .. I can not tell you what PB is exactly. I know its a filler of some kind .. I know its thick .. but what IS pb ? What goes into it ?
Do you see my point now ?
Peace.
YD.
