I read several threads about guys wanting to upgrade cam shafts and intakes and carbs. I haven't seen any that mention anything about going to a better flowing head other than a vortec head. I understand in the general purpose marine world that running a cylinder head that you can drop a tennis ball down the runners is not the way to go. I know there's some kind of factor with the velocity of the small port heads that create the torque. I see a lot of threads mentioning guys wanting to pick up rpms and speed both. Obviously running a cam that starts making power at 3,000 rpms is not the answer either if your wanting to pull a skier or have a heavy boat. Bottom line is it's about making more power and still have that low end grunt, correct?????? Is there a reason guys don't swap a aluminum head or cast iron other than a vortec that flows slightly better than a vortec onto a sbc? Hypothetically speaking what would be the negative effects of using this set up in a 2900lb dry weight boat and if you could change the set up what would you change and why?
small block chevrolet 5.0 and or 5.7 roller cam non vortec
comp cams #08-417-8
intake exhaust
DURATION 270 276
lobe lift .33 .335
valve lift 1.5 .495 .503
Duration @.50 218 224
Lobe Separation 112*
Intake centerline 110*
intake valve opens 25*BTDC closes 65*ABDC
exhaust valve opens 24*ATDC closes 72* BBDC
Holley carb 0-80551 600 cfm vacuum secondaries
Edelbrock intake 2601
AFR 180cc cylinder heads 2.02 intake valve 1.60 exhaust valve
CFM @ 28" H2O intake exhaust
valve lift .200 138 110
.300 198 158
.400 240 190
.500 260 207
I don't know what the flow ratings are on a stock volvo AQ231A exhaust manifolds are but I read any of the stock manifolds on any manufacturer isn't real good.
Why I ask all of this is because i am looking at a 1990 Baretta Phaser 230 open bow. It has a AQ231A but I'm not exactly sure what model the outdrive is. I know its a single prop. The boat has 223.5 hours on it and it's priced good. I'm a person that just can't leave something alone. With the set up I've listed above does anybody see a horrible negative effect? Probably first thing I would do before any parts change with the engine would be to somehow figure out how to put a thru hull exhaust. I'd hope that might free up a little restriction with the exhaust even though I'd still have the stock manifolds. I'm looking for opinions.
Thanks in advance
comp cams #08-417-8
intake exhaust
DURATION 270 276
lobe lift .33 .335
.300 198 158
.400 240 190
.500 260 207
Thanks in advance
