Re: Pics of messed up lower unit!!
Our lake has high water right now from 17 days of rain out of 22 days, Had a great day at the lake and every thing, was on our way back to the loading dock and was far enough away from shore and then out of no where that when it happened, I believe it was one of those rocks that you normally see sticking out of the water 25' from shore, like I said high water, the water was probably at 15' of water where I was at. I was able to get back to the dock to off load the passengers and back the truck up, put boat in reverse, did a turn around to point her to the trailer and loaded her with no problems, no grinding no noise ran like a top, prop shaft is still good and tight, shaft doesn't wobble or any thing, I am hoping that I spun the hub so there is no internal damage, like I said she went in reverse and forword gear with out any noise, real easy like normal.
