:( Please Help me with my 1972 45 hp motor problem. Thanks!
Andy South
Re: :( Please Help me with my 1972 45 hp motor problem. Thanks!
lol! im taking my time in a organized jump around. I should be getting my starter solenoid from ups monday. I got everything put back together and when i get that part I'll get the video going. Thanks for checking back. BTW iM using the chrysler manual for that year. It has 260 pages of great detail. I like learning all about motors.
wickware
Good Pics! I feel you have good plans as to what you are doing. Multitasking is a killer for me vs completing one task with results before moving to another. I?ll be watching vs jumping in as much and will try to help with any question directed to me. Take Care And ?The Best Of Luck With That Monster?! jow
Andy South
hey thanks wickware...
Andy South
ok I finally got my motor to start. sounds great but within 5 seconds it stalls. wtf i checked the primer ball and it is hard and gas is getting into the carb. it seems when i throttle up the motor stays on a little longer but i cannot just idle. does my carb need some work.
please help
rickryder
I would say you need to pull the carb and rebuild it....There is dirt in the idle circuit passages.... get a kit it takes about an hour to do ;)
Andy South
do you think i can find one for a 72 chyrsler?
tater76
You can buy one here on iBoats for around $13 + shipping, but you need the model number off the motor to make sure which one (there are a few to choose from). However, first remove the carb, remove the air screw top front of carb, remove the bowl, remove the needle, take WD40 with the red straw and spray the bejeesus out of all the little orifices/holes until your satified. Reinstall and test before you buy a new kit. Carbs usually just need a THOROUGH cleaning.
In the ternal words of Frank A. " carbs are like womens breasts, they stick out in front and guys can't keep from messing with them" ;)
Andy South
thanks tater ill give them a sqeeze. i mean...
