Pontoon Seat Rebuild and Upholstery Job
Woodonglass
Re: Pontoon Seat Rebuild and Reupholstery Job
Just so you'll know...
craigweaver
Wow, Judge!!! I wondered where you been recently. Now I know. Great thread and those pleats are awesome!
JDA1975
some basic concept drawings of the vinyl design (Definitely not an artist by any means!)
the wrap around
the stand alone X 2
gives an Idea, the rest I just go with what feels right!
Woodonglass
Oustanding design!!!
bajaunderground
I am amazed! That little "project" Skeeter has turned you into an upholstery craftsman (among other things!) I really like the sketches as well, that looks very "automobilly" (I know it's not a word) kinda like an old school upholstery job. I almost cannot wait to redo mine!
Keep on keepin' on!
JDA1975
lol, automobilly.....I was going for boaty, but that works....thanks...got another job lined up...same guy wants 2 bench seats and a table that turns into a bed for his racing trailer next...its not a boat but its a job!
jbcurt00
Re: Pontoon Seat Rebuild and Upholstery Job
Congrats!
Keep this up & we'll have to call you the oops jr of upholstery! Too many sewing gigs to even think about working on your own boat:D Occasionally a good problem to have. Just not for too long! The Skeeter might get jealous:p
Pleats look great!
JDA1975
thanks for the heads up wood, and dont call me oops jr...I wont be cutting any benches in half and extending them any time soon
craigweaver
i like your style Judge. That sketch definately gives a feel for what you're going for. Have a good weekend!
kmarine
I draw my pleat lines on the back of the foam scrim and sew it upside down. This way I do not need to worry about cleaning it off the vynil, I use a regular #2 pencil to mark out my vynil pieces. I also find it easier to make large enough pieces to make numerous seats and then i cut the paterned piece last. This way if your pleats shrink your seat it does not matter because you have not patterned it yet. It is essentially like using heat embossed pleated material. I have found I make less mistakes and save time.
JDA1975
thanks Kmarine...funny you should say that you sew it upside down...that is in fact the solution I found as well...worked a lot better, fed through the machine easier...I had to take a little time dialing in the machine so that my bottom stitch was as perfect as my top stitch, but it worked out
Woodonglass
Did you get your speed control dialed in??
JDA1975
I did add the cardboard and it does keep it at a slower overall speed, but still do not like the trigger on this control and think I will spend a few bucks and get a new foot control with the pedal action I was used to before, they only cost like 30 bucks and seem easy enough to rewire
kmarine
I recomend an electronic type. less heat buildup and more pedal control. Usiually $15 to$25 See if you can find one already wired for your machine type. It is unfortunate your machine does not have an external motor. Otherwise you could change pully sizes to slow down your machine.
JDA1975
yeah, my machine is sub par for the job really...it is a nice machine, but I am in the market for an industrial walking foot since it appears to be a very viable business venture...I have not been looking for work long and have 3 jobs (current one, the race trailer, and a 22' ski boat) and one possible that my wife's friend wants done...already feeling overwhelmed lol, and a new machine would definitely make things easier and that much more professional. It is amazing how quickly one little thing can change goals in life. was talking to the guy that owns the marina and he said we haven't had a good upholstery guy around here for a while and when the season is over I should expect even more work
JDA1975
epoxied the insides of the frames...this stuff has to be done prior to covering it with the finishing wood, inside will be hollow but look solid when I am done
I don't like this part, can't stop and take a break until it is all done because it has a limited working life
craigweaver
That looks great Judge! You're doing an awesome job on those seat bases.
JDA1975
got a second coat of epoxy on the insides and installed my kick boards today, have the seat bases cut, but cant put them in until i get the 1X2s ran along the lips I left in the supports. I did everything else out of 3/8" ply for lighter weight but kick boards and seat bases are 3/4" for strength
Woodonglass
I'm thinkin you might want to make a double set of these and leave one set at the house in the basement and open up a BAR!!! I'll be one of your first customers!!!!! Very Nice Work...AS USUAL!!!:D
