Re: Poor Man's Skiboat...Restore?
Probably the same one I saw, Jay. I am going to have to wait before spending any more money on the boat unless it is for paint. I have a good engine that really looks like it only has 300 hours on it as my meter says and I should stick with it for now. If the lower unit of that 260 is good and it is available end of January I might pick it up.
Today I only got one layer of CSM on the main three stringers and I am 100% confident in the strength, but hate the way it looks. PL is some tough stuff, but it makes filling the gap between the stringer and hull very hard. The CSM is stuck to the hull with little to no air bubbles and stuck to the stringer with little to no air bubble, but in between there are unavoidable gaps.
The good news is I didn't use nearly as much resin as I thought and have at least 7 gallons left. I was forced to thin the resin out with acetone in order to get it to flow properly and though this maybe bad form it really seemed to remove a lot of air bubbles. I have enough CSM tape left to do a full 12" on each side of the stringers which will overlap between the center and outer stringers creating a good bond and extra strength. Then of course the entire thing gets gone over with 1708 12" tape. I cannot get the csm to wrap over the tops of the stringers without coming off and bunching up. I have some thinner 7oz cloth I may use to cover the stringers, but they are so saturated in glass I am really not concerned about water getting into them.
Overall I am happy with my first major fiberglass job. It is NO WHERE near professional or as good looking as Chris Hayes' job, but my angels are very tight and I am guessing Poly doesn't stick like epoxy would. With just the stringers being bedded with PL the hull feels much more ridged and this is already one huge step above how the stringers were bedded before (they weren't). As long as my glass buildup along each side is substatial and the bonding to the hull is good my boat will be fine.
Pictures later, I am too tired today to snap any and there is a lot of CSM on tops of the stringers that has to be cut off in the transom area.
I saw a 260 and drive on CL for 350.00. I can get you the number is you want to go look. It is in Burleson.
