Hi all, I need some help propping a 20hp yamaha 4 stroke on a tiller boat. Details as follows:
1) Performance issue you are trying to correct:
Very slow to plane with 2 people or not at all, more top end if possible
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Yamaha aluminum stock
3) Current prop diameter and pitch (required).
Stock Yamaha 9 1/4 x 10 - 3 blade
4) Wide open throttle RPM and speed with an average load (very helpful)
** RPM's taken with tiny tach - wrapped around both spark plug wires (when wrapped around 1 only gives half the RPM's at WOT)
1 person - 6000rpm - planes fairly quick - 24mph
2 people 1 large, 1 small adult - 5700rpm - very long to plane - 22mph
2 large adults - less than 5000rpm - won't plane - 12mph
5) Engine/drive make, model, year, and HP
Yamaha 20hp 4 stroke
6) Boat make model, year, length and weight
14.5ft tiller vhull 500lbs dry weight
I'm wondering where I go from here - alone it runs good and at max RPM so can't really drop pitch. Would a 4 blade help? WOT rpm range is 5500-6000.
Also, motor cav plate is also 2.5in below bottom of boat. I might raise it via mini jacker or building up transom but not sure that will help that much with the planing but should raise RPM and top speed a bit. Would prefer to change props rather than start drilling transom etc. But, if I have to, I will
Thanks
Thanks
