Propeller pitch
natedog337
What's the rpm and speed difference between a 4 blade 13 pitch and a 3 blade 15 pitch prop
QC
Re: Propeller pitch
You probably need to read up a little more on props. Check the stickies above. I could say that the RPM difference would be about the same, but not enough info for that. Usually we say one inch less for four blades vs 3 to be at the same RPM. No way to judge speed with out a lot more info. Boat, engine/motor combo. Speed and RPM today and with which prop? etc. etc. Get us some more info, and we'll help best we can. Mo info = mo betta . . . :)
natedog337
Re: Propeller pitch
Thx for the info
I have a 26 foot pontoon getting 27mph with Solas 13pitch 4 blade prop
Yamaha f115 on the back..
QC
Re: Propeller pitch
RPM? Speed is GPS?
QC
Re: Propeller pitch
Ok, based on what I am seeing, with the 3 blade and 15 you may bring RPM down towards 5500 and could possibly reach 30, but that is assuming a lot. Being the middle of the WOT range is good, especially if you are running typical loads and your hole shot is OK. Pontoons are unique as well, and I don't have much experience. Why do you want to change props in the first place? What do you want to achieve. Can you elaborate?
natedog337
Re: Propeller pitch
To be honest I'd like to have an extra propeller inboard incase of emergency and figured I could try to get a little more speed out of it
QC
Re: Propeller pitch
Then you should try it. One or the other becomes the spare, and I think you are going the right way, especially with a four stroke. As long as the acceleration is good now, became what you plan will cut into acceleration a little. Props are really hard to guess at, although someone with some specific pontoon experience might be more helpful.
steelespike
Re: Propeller pitch
The motor max rpm is 6,000 your at 5900 and 27 mph on a 26 footer with your present prop.That seems very good to me.
You could try the same prop in stainless, if it doesn't break the bank.And use the aluminum as a spare.
QC
Re: Propeller pitch
Is 20% slip reasonable with a 'toon, spike?
