Radar 10x raytheon
Vinnys
I have been getting Bearing zero pulse error on my screen. Any Ideas?
I have a problem finding the 6.3 amp fuses for this unit. I found ones in 250 volt not 12. How bad is that? Can they be used?
dingbat
Fuses are rated by maximum allowable voltage. It's the amperage rating that matters
SteveMcD
My radar has a microswitch that is cam operated at 0 degrees. Seen a 0 degree switch on another radar too. My guess is yours has one too. The 250 volts is the maximum voltage rating of the fuse. It has nothing to do with the current rating. It is probably the most common rating I have seen. You can use them all day long. 6.3 amps is strange sounding, though.
