Ready to buy an inflatable
ronaldj
Re: Ready to buy an inflatable
I just bought my 9.8 Tohatsu yesterday. NO BOAT! We should hook up but I am not wanting go clear to Long Island so ya can head out to Colorado. :joyous: Congrats on the boat.
On edit: I see boats to go sell your Azzurro as well as their Saturns. Seems they are about the same except the Azzurro is a couple of hundred more. Any reason why you would chose the Azzrro over the Saturn? I do see they have a 5 year warranty and 10 lbs heavier. I even saw where Boats to go got mixed up in their add and mentioned it was an "AM365 Saturn" Can you give me your reasons for the Azzuro over the Saturn? I may just order one myself.
Azzurro boats are Upscale Saturn boats
They have a few more features most notably a thicker bottom 1.5mm vs .9 mm
Thus the difference in weight.
If the boat is to be used in saltwater the Azzurro is a better boat
With that being said however.
If I was to buy a boat from them it would be the Saturn SD330W
The extra width comes in handy as a fishing platform
Btw
If you plan on leaving your boat inflated and outside without a cover then you will need a Hypalon boat as opposed to a PVC boat
PVC is cheaper but Hypalon last longer and is much more resistant to UV rays from the sun.
PVC can be treated with a UV protectant , but you must constantly apply it and you must keep the boat covered.
That is not to say that you can't maintain a PVC boat for 10 years or longer.
It will just require a lot more work on your part.
If you keep the boat deflated in a bag when not in use or out of direct sunlight then PVC will have a very long life
Most people with a PVC boat got it as a first boat or as an upgrade from a raft type boat.
By your second boat you usually go Hypalon
pgnyc
Hi, by waiting too much , the saturns are out of stock, and i would like to be ready soon,
Have to do the DMV registration and more. (Life jacket, anchor, lines, have a trial on inflating/ deflating etc)
Pascal
ronaldj
Pascal
Check right here on Iboats
Look at the Maxxon or the Zodiac
If your heart is set on a Saturn, you can also checkout Coastal Inflatables .
They sell the same boats
Also isn't there a Mercury dealer near you?
pgnyc
Hi ronaldj,
thanks for your info but i did buyt it yesterday night on boatstogo.
about the dealers, it is a nightmare to find them if you do not know them before !!!!!!!
i found a tohatsu dealer in Brooklyn at Venice Marina near floyd bennett but theyre was nothing ready in February , no sales people for outboard yet !!!!
Pascal
Chopperbill
I did want a cover but I see the Azzurro has tube tops. Not to sure I care for them. Is there a cover available for the Azzurro. Don't find one.
G
Guest
Guest
Hi ronaldj,
Pascal
Do not go to the marina by floyd bennet they are a rip off and do not know what they are talking about go see bay end marina on ave u and east 68th st. They are awesome nice and will treat you the same if u have a 9ft inflatable or a 28ft boat
TOHATSU GURU
Just so you guys know. The thickness of the material isn't really important. The usually measurement given is for denier which is the thread count/weight of the material (not that important either unless it's either really high or really low). All of these PVC boats are low end, including the brand's we sell too, and are not to be confused with a boat made out of Hypalon. In a low end boat just look for a difference in features, whether the boat is welded or glued (glued makes it a 5 year throwaway), price and the warranty. In looking at a warranty you have to consider whether or not the warranty itself is enforceable and any expense you may have to pay to try to get it enforced. IE Proximity to a authorized warranty center for that brand is critical.
pgnyc
HI !
so it seems that my boat and my engine are coming tomorrow !!!!!!
after reading the tohatsu 9.8a manual , ii is my understanding that you need to replace the split pin with a new one each time you remove the prop .
do you really have to do that if for example you remove the prop to flush with fresh water ? (yes, already have question before having it !)
Pascal
ronaldj
You don't need to remove the prop to flush with fresh water
cablebandit
I am a recent buyer as well with never owning any sort of boat before. I purchased an Achilles LSI-122 (12'2"). I inflate/deflate every time and have the pull up to the ramp to putting in to the water at about 22 minutes. I use a coleman air mattress pump do inflate each tube and top of with a Bravo 10 foot pump. I wanted to get an electric pump that does high pressure as well but I can barely keep up following behind the little coleman pump so i doubt id save more than 5 minutes TOPS. Bimini top will be my next purchase as well as an anchor. I hope you enjoy your boat. So far mine has been a blast and I am not a lake person but more of a cove/exploring type person.
G
Guest
Guest
The electric pump is more for ease of use. Summer time you can break quite a sweat foot or hand pumping
ronaldj
If you have an air floor you really need the electric pump.
You set the pressure and the pump automatically cuts itself off when the floor is the right pressure.
It works way better than using a foot pump
cablebandit
I'll have to look into it when it gets really hot then. right now I look at it as forced exercise which is not a bad thing for me.
fbpooler
That Achilles LSI-122 is a dream machine which would be on my wish list if we wanted a new inflatable. Congratulations.
After you fight the manual pumps to inflate the floor a few times, you will see the need for an electric Bravo. It would be money well spent.
pgnyc
HI,
so i just got back from the DMV and i have the registration & sticker : 30 minutes !
Yesterday night i received :
- the boat
- the 'expensive' pump
- the wheels
- the outboard.
- oil & lube
Waiting for the stand now !
i just had time to open the boat box and put it in the bag , oh MY it is heavy : 120 pounds !!!
This morning , after charging the pump all night, i inflated the boat .
it is very easy and fast with the pump , dial the KPA and voil? .
ok , i follow the instruction , so inflate at 50% first
there is a wood plate under the middle of the air floor.
At first , i thought they forgot the tube cover but no , it was there on the tubes !!!
it is fixed to the boat with velcro all around .
I did a dry fit for the wheels and on the right side ( looking from the stern , one of the hole will be in the manufacturer plate.
do i use only 3 holes / 4 or drill through the plate ??
i am very close to go to the water, just need to make the registration plate, buy life jackets , and lines.
Pascal
ronaldj
You will need a hand truck to move the folded boat
G
Guest
Guest
Enjoy, that boat looks bad arse! I would find a way to ensure the transom wheel frame is screwed in with 4 bolts. Remeber that frame will be holding out the entire rear weight + motor + gear
Chopperbill
I could foresee a problem with the registration plate when mounting the wheel. Can you move the plate to different location, or is that legal?
ronaldj
No
You can't move it.
Can you take a picture and show us so we can come up with a solution
Chopperbill
You can see it behind the right mount towards the top.
