Outback Jack
- Joined
- Apr 23, 2010
- 267
Re: Regelcoating catwalk and engine covers
I sprayed gelcoat everyday..I use to coat up to 85ml , in one coat, was the finish acceptable to look at as a finish...No...is was to be chopped after so it was acceptable. Myself I would roll it on a deck.
That is why there are so many different opinions here at iboats. Seems to be a trend here debate between pro's and diyer's . Some people are diyers and some people are actual pros. GUYS I don't say a Pro is someone in your back yard or who just opens up a shop to start. Damn I got maney years experience spraying molds and running chop gun everyday building and designing everything and I am no PRO at Finishing A Boat to the level I would say A Pro did it :facepalm: As for laying fiberglass I am the BEST
I worked at a welding shop we built trucks for different companies right up to cherry pickers etc, You get it we start with a cab and build on from scratch and actually weld the body together. I use to spray primer etc but never the finish. I tried to do some work to my old bronco one time and it turned out ok but who cares when your going down the road. I could have taken the truck up the road and had a shop do it for less then what I paid for product. He is no pro and he admits it but he makes it look good for a couple years.
My buddy is an actual Pro at redoing cars and will not redoe any car . He did my Trans am 19 years ago and people don't believe it has ever been painted I paid BIG Bucks , but let me tell you that is the difference . We can do good work and make it look real good but if you can bring your work up to a Pro level you are no DIY'er
That is the thing let's share our findings and experience of working with the products and we will get er done and look good . As for the Pro they have experience and know what works for them on a daily basis and also they see what never worked for them . Over their years of being a Pro. I want to see stuff they done 20 years ago and if it lasts. Also Pro's have to remember we are diy'ers and don't have the tools or access to supplies , we have to use what is available to us. For instance Wax
As a Diy'er we get the gratification of seeing our final product get praise for a job well done. Is it at a pro level well maybe not but it looks damn good and ya feel damn good looking at the finish product.
Myself I take advice form all but when it comes down to which way i go I look at experience and I thank the experience'd for their advice. Experience means alot more to me then looking good when it is done, look at it in 5 years .
Let's all work together and get er done
I come here to share and read good projects not to read about who does it the best way or who get's support from the gods and you know who they are , be it they are pros or diyers.
Hope everyone the best of luck.
Cheers
Jack
I have NEVER seen gelcoat applied with a sprayer as thick as rolling it on.
Sure there are additives for gel coat but wax is just fine. It works, period. If the gelcoating is done at the dock it is standard practice here to use gelcoat with wax and then remove the wax with acetone once cured. If you can do multiple coats in a day, then wax only in the last coat. May be easier ways, but that doesn't make this the wrong way.
Cheers
Jack
