Re: Regelcoating catwalk and engine covers
Any way to tell if the resin below the white is poly or epoxy? I was told it was gel but you hear everything but money jingling and bacon frying.
I can tell Epoxy from Poly when I sand on it just from the Smell. You should be able to tell .. there is a distinct difference between the two resins.
From your first pic I am Assuming its Epoxy from the transparency over the cloth without too much distortion in the resin/wood. ( color/finish ) However there are some Poly based resins that have more Color character to epoxy.
As far as it being a Gel coating.. it does not appear that way to me.
1. The uniformity of the pattern of the nonskid ( shown on your vents ) dictates that the coating was Sprayed and Not rolled or Brushed.
2. The nonskid chunks are too big to fit through a normal Pressure pot gun. Yes there are Dump guns that can apply larger skid additives with Gel .. but its not really worth it in normal Gel spray coatings.
3. Not to say its NOT Gel .. but anyone that has that kind of experience to shoot chunks with Gel that Thin would KNOW that its Very risky without some kind of Gelcoat Base.
There are a few reasons why I think that your "top" is good and your deck is failing ..
I dont think I should go into the Whys right now..but I can say that Normally the Tops get Done first
$$ thing ..
It was a missed window of application or Improper prep. I can not think why your lower would fail and your top does not fail other than those 2 issues.
It could have been something to do with the PO holding back $$ .. or It could have been new guys on the job and the application was not correctly applied within its window or application.
Who knows for sure what Really went down in the application of the materials ...
Does not matter at this point .. you have your surface .. what do you want to do with it ? Your going to start over again .. Cheese out the prep and roll on some truck liner ? Gel it ? Paint it ? ..
You are Looking at a Fresh Start M8 ... You can do basically Anything you want as soon as you get it back to the Good Substrate.
What are your thoughts on this Proshade ?
YD.
