Does anyone know anything about this topic, how dealers do it, if they really put in the correct block, how not to get screwed.
You might try posting the SN of the block you received. It may or may not be Mercruiser number. You should have received some warranty information from your dealer if it was a Mercruiser reman. Did you ???????
This motor had a mercruiser serial number plate on it. Upon removing the motor it turned out to be a two bolt main. These reman guys are going to try to sell you on this issue and justify the price.
the thing that gets me is i was told that i needed a new engine coupler, so basically he could order any motor and just match it up with my bravo 1, right?
Wow,
the word "remanned" and GM really polarize an audience!!. Actually Brunswick purchases the GM sourced blocks from Tonawanda engine plant 1 in Albany New York for Mercruiser. The earlier blocks were the same units used in G Vans (Gen I). they had 4 bolt mains and cast numbers included 010. Brunswick sonically tests these blocks for cylinder core shift and discards about 50% of them to rebuilders (good enough for passenger car service). Originally Brunswick Marine specified High Tin alloy block for added rigidity. These blocks were sought after by the racing community as a foundation for Pro Stock motors. The newer Gen II and Gen III (Scorpion) are regular production due to better casting and machining quality.
Wow,
I have read a lot of BS on the internet over the years.
The above ranks near the top.
