fisherman81654
Thread starter- Joined
- Sep 5, 2011
- 135
I ordered a new stator because I thought it was causing me too lose rpms on top end.
The stator I had was the older one that was black,which I have been told by a tech,that it could be the problem and if its not the problem,it wouldn't last long anyhow. at least now I don't have to worry about that and I did a dva test on the new stator and the older trigger and switchboxs,all in specs.
My problem is the boat used to run with lots of Power!,at 5500 rpms and it would go to 6ooo rpms.I f remember right about a year or so,I was running down the lake and the motor started missing ,like you were taking a spark plug off and on,then it stopped making that sound.I believe thats when the problem occured.
Now all I can get out of is 5200 rpms.
The bow used to trim way higher than I needed,now the bow is just lever.
I have good compression,120 on all six clinders.
New plug wires.primer bulb pumps up hard and stays hard,new fuel filter,rebuilt fuelpump two years ago,although after the run today on the lake I pulled all the plugs and they were all wet except the top one on starboard side, it was dry and the top one on port side was just a little wet,I don't have a fuel guage to test fuel pressure.Thought about taking the lines loose were they go onto the carbs and crank the engine and see what kind of stream I have .I have not tried this yet.Can a trigger be bad and dva test ok?I have decent fire on the plugs on all six clinders. Does the top carb feed the top two cylinders?,if so could the top carb have a problem feeding one of the top cylinders?
