Re: How bad is this guys?
Ok guys I decided to give this thing a shot. What I found out from Bayliner it is a 1989 Bayliner Capri SKI usually comes with 125HP engine but this one has 150HP. I noted the engine serial number still have to look up the year. Did check the compression and I get 130 in 4 and 120 in 1 cylinder so that makes me happy at least that works
I have attached more pictures of the ripping out progress I made today because I want to know what I am dealing with. It seems that the transom is ok from at least what 2 drill test could confirm. I also checked stringers and there is 4 of them in the main part of the boat under the seats and all 4 of them had yellow clean wood shavings when I drilled into them. However the stringers on the front part (Bow) of the boat are rotten the two main ones are so I will definatley have to replace them. Also what I found out is that someone was patching them up and was reinforcing them with 1x4s but did not do a prop job and sealing and fiberglassing them so they rotted as well. It also seems that someone replaced the foam at least under the seats is not wet I did a pvc pipe test and comes out dry ( stupid question here, if I wanted to take that foam out and create space for coolers etc under the seats would that be a very very bad idea?) Is there somewhere else where I need to test the foam?.
So for now I know 100% that the stringers in the front (BOW) have to be replaced and boxes for seats remade. The deck has to be replaced and I am planning not leaving a ski storage in the middle but rather cover the whole thing up for support but am thinking of taking out the foam from under the seats and creating storage there. What do you guys think. Please let me know if I missed anything else. I am pretty handy and I rather do it right the first time.
Also where is the best place to buy supplies , (Resin, fiberglass, Plywood I am thinking Home depot )..
