Re: Restoring 1986 Sea Nymph SS155 (pics)
For my dash I am think of doing plexiglass/lexan and painting the back side with matching red auto base paint. The clear material should act like a clear and make the color pop. I have been doing reading on the best ways to do this. Using steel wool or 1000 grit wet sand to prep surface and then paint...
I have been told that lexan is better than plexiglass as its more sturdy.... but according to fshngho in a recent thread he states "Plexiglass...NO, Lexan yes. Similar in most ways but lexan will not break. That means you can use 1/8" thick lexan, which means you can bend it..in a break if you want, just like sheetmetal. You can get it in all colors & tints, dark gray or dark bronze, black, red, blue, etc. Plex and lexan are an oil based material which means paint will not stick. Maybe for a short while but it will peel off. Ever tried painting something after you coat it with WD-40?"
I have done some reading and many people have painted plexiglass with success for many applications... plus all high end R/C cars are made from lexan and people custom paint these all the time.
Questions: Has anyone performed this with success? Good application? Paint to use?
Thanks
