I'm new to I/O so forgive me if these are ignorant questions
1988 Baretta Success Bow Rider Volvo Penta AQ131A and 275 out drive.
I'm trying to run the engine in my driveway to time it and warm it up enough to change the oil. I bought those muff thingies that you hook to a garden hose for a cold water supply. I dropped the drive down, attached the muffs, hooked up the hose and turned on the water. Then I started the engine and let it idle. I watched the out drive carefully for 30 seconds to a minute and saw no water coming out of anywhere other than around the muffs.
I know on outboards there is a tell tale, but I don't know if there is something like this on an I/O. Is there?
Maybe the engine has to be running at more than idle RPM?
Does the transmission need to be in gear for the pump to work?
I've read about replacing the impeller, but I can't find where anyone really describes where, on this engine/drive combination this pump is. I have a water pump on the front of the engine with 4 bolts (2 10mm and 2 8mm) but when I cracked the bolts I got antifreeze coming out not fresh water.
This boat hasn't been in the water in a few years so maybe the pump needs to be primed?
Any assistance that is offered would be appreciated.
Thanks!
Thanks!
