screw in cam oiling felt ?
orlandoclippertim
I am replacing the ign. parts on the plate on an RDE-17. I was supplied with a new oiling felt for the cam---- but it looks
like the holder has a tiny hole that there might have been a tiny metal screw to retain the felt in the bracket...... Can someone confirm the use of a screw there ???? and what size ? looks like it could be a #3 or #2 (tiny)
Also - incidentally--- does it make any difference which spark plug is driven by which one of the Ign. sides ?
I cant think of any reason why it would since there are only 2 cylinders-- and no "firing order" ...... :)
Just getting back to my boats and motors ! Been doing other projects for a while......
Thanks--- Tim
(I would like to get two of these built up and run twins on the orlando clipper)
No screw in that item !----The bracket will hold the felt in place all by itself.----It sure does matter which plug wire you put on the top cylinder.----The front coil fires the top cylinder !
F_R
The jagged edges of that hole you are looking at poke into the felt to hold it from sliding out of the clip.
kbait
The ‘screw’ location on the Oiler-felt holder is just a dimple to help secure the felt on install.
orlandoclippertim
Thanks to all there on the felt. I guess the hole is just where the little triangular teeth came out from. I actually
found a microscopic solid aluminum rivet that fit through the hole- I used that to hold the felt on. It should be easy to remove
when the felt gets changed.
I guess even though it doesnt have a distributor--- it does have a clock position on the crank where the intake happens---
so if the plug wires were reversed you'd be sparking at the incorrect time in the cycle sequence -------- that makes sense now----
I had marked it on the ignition plate with a sharpie--- but washed it off accidentally when I took the plate off to clean it.
Front goes to top----- that will be good to get correct :)
I will be testing it in the next day or two to see if it will run as-is. At least all the IGN will be new. I looked down the
carb inlet and it looks spotless ( no shellac or bugs or mud dobbers or visible corrosion)
I have a carb overhaul kit comming next week and a new water impeller. I made a flush device to go on the
reverse water intake. ( I read that was the easiest way to get water into it with a water hose for flush and testing-)
I am hoping that will supply enough water to run at idle safely . (assuming the impeller
doesnt work---) (opinions on that ?)
Should I go ahead and do the water pee-er mod on top to be able to see the impeller working for later on when Im running
it in the boat ? (doing a light restoration of the motor now)
Tim
