Re: Sea level to 6,000ft: which pitch would be good? '87 Mercruser 2.5l Aphha1
Seems like that 2.5L runs pretty well in the Glastron, 4500RPM at 42MPH with a 19P prop, is that GPS speed or off the speedo? What type of load are you going to carry while up in Tahoe,,, and how does that compare to the load while at sealevel?
The boat seems to run strong so you could try a 17P prop, but I bet a 15P would work much better. I'm running a 140HP Mercruiser in an 18'er and a 17P is a dog up at that type of altitude, but a 15P works fine. Different boat, with a different load, so your prop selection could need to be,,, different....
High altitude requires more fuel during operation to preform but more fuel at lower levels will damage the engine. Basically you can go from low to high and not hurt anything, but you cannot go the other way without damage (way to rich).
Ummm, it's the other way around... High altitude requires less fuel, so the carb
could be leaned out to help compensate for high altitude, but this would need to be reversed when dropping in altitude,,, so the engine doesn't burn up due to too lean of a fuel mixture.
When I go up in altitude 6000-8800' I re-jet to lean the fuel mixture, bump the timing a few degrees and swap props, but it's kind of a hassle since those changed need to be made before and after a high altitude trip. Mercruiser recommendation is to only swap props, unless the boat is going to live at high altitude.
