Sea Nymph 17' Deep V.
mark mcj
Re: Musky livewell
Re: Musky livewell
Yeah, I see what your talking about.
The two things I don't like about putting the live well off to the side where the port console is/was is the balance of the of the boat across the beam and seating arrangement.
I just started since the weather broke and have to finish the demo first. Lots of thinking :eek: and measuring to do.
LonLB
Re: Musky livewell
Re: Musky livewell
After taking some measurements, at this point anyways, I think I am back at putting it under the front deck.
I was going to avoid that route because I wanted to put under deck bow rod storage. Problem is I need at least 7'6 if not 8' of rod storage, and I think that is too much for a boat that is barely 17' long.
Teamster
Re: Musky livewell
Re: Musky livewell
I prefer having the live well width ways at the back of the boat,.....It gives the fish the best possible ride,...
Of course that is when tournament fishing and the safe live release of the fish is a big deal,..
LonLB
Re: Musky livewell
Re: Musky livewell
I probably would do that except one problem....I don't have a built in fuel tank, and it's going to be a tiller.
I wouldn't be able to have a fuel tank and batteries, and then a livwell, and still be able to operate the boat.
by built in tank, I mean in floor tank.
LonLB
progress
progress
Finally some decent progress. Built a new bow area board to reinforce that area, and make installing lights, and trolling motor an easier/more solid affair.
And cut a new brace that matches the factory one I took out. Both out of Marine plywood (I had a few small pieces laying around)
Also got most of the paint stripped off on the starboard side.
And, got the splash well out, and the transom board out. Luckily I was able to get most of it out in once piece. This is going to make it MUCH easier to make a pattern!!
Later today I'm going to make that pattern, and cut my new transom boards.
I may also work on shortening the splash well.
My new goal is the end of March. If I don't make it my world won't end, but I'm going to shoot for it.
LonLB
Prop advice
Prop advice
I NEED A PROP RECOMMENDATION
65hp Johnson. (73') It currently has NO prop.
Boat is right at 17' long, Bottom at the stern has a very shallow V. Tiller operated.
I have a set of automatic trim tabs, that are spring loaded. They are approximately 8" wide but only protrude from the boat about 5" or so.
LonLB
Corrosion??
Corrosion??
I need some help here guys.
Specifically what you did to "fix" corrosion. I found a few places on the transom.
I'm comfortable with not having them welded, or adding more aluminum, but I'm not comfortable doing nothing.
Any ideas?
I was thinking of filling the pits with JB Weld.
Oh yea, and ideas on Prop's would be great too.:)
Huron Angler
Re: Corrosion??
Re: Corrosion??
You could rivet in a new patch of good aluminum if it's bad, or just hit it with a wire wheel and paint over it to protect it.
iboats has a prop selector, maybe post a new thread in the "props" forum for good advice.
LonLB
Re: Corrosion??
Re: Corrosion??
Post up a shot of it Lon, sos we can take a look, eh!:)
Well, I just tried. I'm sure it's probably my skills are lacking, but I couldn't get a decent photo.
EDIT That actually turned out better than I thought it did. That's the worst spot.:(
I did measure my aluminum thickness on the transom and it looks like it is .110 according to my calipers.
I would say the worst spot is close to 1/2 way through, and is about the size of a pencil eraser, the others are less than 1/4 through. Maybe 1/8. But bigger-about the size of a quarter.Picture 040.jpg
LonLB
Yikes
Yikes
jasoutside
Re: Yikes
Re: Yikes
I think you are going to be aok, no sweat. I am thinking a quick wire brush, scrub with vinegar/water, etching primer, primer, and some paint to protect it. The other guys may chime in with some other thoughts though.
LonLB
Transom boards
Transom boards
One other thing.
Given the option of Spar Varnish, or POLY resin which would you guys choose?
Also any local sources carry the Z/C primer?
ezmobee
Re: Transom boards
Re: Transom boards
Poly resin is useless unless you add glass to it. It will crack and peel. Epoxy resin can be used without glass.
LonLB
Prop again
Prop again
I didn't find what H/A was talking about...
I found some more info to throw out there to fish for a recommendation.
Gear ratio 2.42.1 5000-6000 RPM.
Huron Angler
LonLB
Re: Prop again
Re: Prop again
Sounds like I'll start with a 17p prop.
BTW I NEED SOME SERVICE MANUAL INPUT
Would you buy one of the universal Seloc manuals, or a manual for a year newer engine and 5HP more.
My engine is a 73 65hp 3cyl Johnson. I found an original OMC service manual for a 74' 70hp 3cyl Johnson.
Go for the Universal, or the OMC Service manual for the 74' 70HP?
